Injectors
Old Feb 11, 2009 | 10:57 PM
way2much_01's Avatar
do I need any type of spacer?
Old Feb 11, 2009 | 11:22 PM
blackbeast ss's Avatar
no if you get the GM shorties you dont need spacers
Old Feb 12, 2009 | 05:12 PM
Mort's Avatar
Can you get the shorties at 60 lb/hr? I have only seen the 8.1 Marine at 42 - 44 lb/hr. I just ordered some from Fuel Injector Connection and they are LS2 with adapters and I will have to shim them with some washers or something and probably need longer bolts. Jon claims they are a much better injector.
Old Feb 12, 2009 | 05:42 PM
SRT10KLLR's Avatar
Former Vendor
is there a big difference in gas consumtion with bigger injectors?
There should be no MPG difference as the injectors that flow more are just pulsed less to maintain the same a/f.
Yes you can with no pigtails/adapters needed. Just drop them in change your IFR and your pretty much done. No need to adjust PW min/max, dead times etc.
Old Feb 12, 2009 | 05:45 PM
Mangled03gmc's Avatar
Baltimore Whore
Def a badass injector, made life much easier
Old Feb 12, 2009 | 06:37 PM
Mort's Avatar
Sounds to me like you should contact SRT10KLLR. His solution will definitely be easy to tune and ease the install process. As near to Plug and Play as it gets.
Old Feb 12, 2009 | 06:40 PM
charcold-bowtie's Avatar
my IDC last night was at 95%, on the 42's, I may get a set also sometime
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
