injectors for 08 silverado?
Old Dec 2, 2013 | 07:56 PM
SpoolinLongBed's Avatar
Registered User
Default injectors for 08 silverado?
Hey all. New to turboing a beached whale but not to boost in general. Im lookin for 60 lb injectors for my 08 4.8 chevy. All the injectors i find are for trucks up to 2006. Can someone help me out here?
Old Dec 2, 2013 | 09:00 PM
Budakane's Avatar
Welcome to PT.net!!! Some1 will chime in shortly with sound advice, but while you wait introduce yourself in the new members section.
Old Dec 2, 2013 | 09:34 PM
RS/SS 4.8's Avatar
10 Second Truck Club
I think our trucks (07+) use the EV6 connector. I may be wrong. The aftermarket ones are usually taller than the OE injectors and the fuel rail has to be spaced up to compensate for the added length of the injector. Or you can also get the EV1 style injector and a conversion pigtail for EV1 to EV6 or vise versa. The latter is how we dit it on my 2010 5.3.
I got this off a post that Fuel Injector Connection made a while back
Starting with F body 98-02 uses a EV6 60mm long injector with the mini timer Bosch plug commonly called EV1
99-07 5.3, 6.0, 8.1 uses a mini Delphi plug. And a 48mm injector Except for flex fuel trucks which use a Uscar plug commonly called EV6
08 up trucks all use the Uscar plug and a 48mm injector
04 GTO uses mini timer plug and a 60mm injector
05-06 GTO use Uscar 48mm injector
All Trailblazer SS use Uscar 48mm injector
05 up corvette all use Uscar, LS2 is 48mm, LS3, 7, 9 is 38mm..LSA caddy is same as ls9,
early ls1 cts uses 60mm mini timer plug same as F body
All 2010 camaro to present use Uscar
Pontiac g8 uses Uscar
Hope that helps
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chopperloco
Jul 10, 2016 10:45 PM
mzoomora
Jan 3, 2016 07:06 AM
Slammed96
Jul 27, 2015 07:22 AM
Deceptarado
Jul 8, 2015 05:24 PM
