IAT Temps, Whats acceptable and whats not?
If we go by flow inches we are close in price.
1235 part you mentioned 325.50
12.5 x3.5- 43.75 flow area.
Trick Race 3" - 500.00 core only.
23X 3.0 - 69.00 flow area.
Now the way you have your pipes set up your pipes would have to be reworked.
We designed our intercooler to be largest core possible for these trucks with minimal to no hacking the truck up to fit.
With china cooler i seen temps up to 225* leaving the line at 120* (105 ambient)
They're junk imo.
For all claiming they work just fine spraying a gallon of meth, if you ran on the track with and without the ic id be willing to bet times would be equal or even faster without the ic.
They're junk imo.
Just an update, took the truck to the track yesterday, it was about 75* when I ran it. Iats went from 82* to 108 after the burnout, throught the traps it was well over 190*. Needless to say, I ordered the Treadstone intercooler, the TR1235...
Haha I understand.
Also, you still haven't released who builds your core. Maybe it is a treadstone core. Price is similar to garrett core which is top of the line A/A IC
Wow not as good as what compared to what?
Where did you get that information.
What cores are you comparing?
What is the comparison air temp, boost drop across the core?
You know the difference between a vertical core and a horizontal core.
90 degrees
The only things that matter in a core.
Type of design
Tube length
Flow area ( boosted air path)
Surface area in natural air flow
How it fits the application
If we are comparing price what does a Garrett cost if it was build as large as the ones I offer? I have never checked.
Again, none of the big names build vertical cores unless space limitations. Horizontal is preferred.
The baddest Garrett 28" x 5" IC core is around $700, fully built $1k.
Trick, I'm sure your product is good, but don't compare apples to oranges.
