IAT reduction with radix 90mm
Old Sep 30, 2008 | 10:58 AM
PSM's Avatar
PSM
Default IAT reduction with radix 90mm
Is there a noticeable difference in lower IAT's with a 90mm on the radix. I going to run my radix for the first time with just the 90 so I was curious
Old Sep 30, 2008 | 11:21 AM
zippy's Avatar
I read that alot originially, but never seen that to be true. You should however get more boost with the 90mm over the 78mm with the same pulley size.
Old Sep 30, 2008 | 07:49 PM
PSM's Avatar
PSM
I was hoping that the loss of boost from long tubes is offset by the 90mm TB.. I know boost = equal power but just a restriction to flow.. but I feel kinda lame with 4-5psi of boost
Old Sep 30, 2008 | 08:00 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Time to pulley down.
You might pick up a half-lb with the 90mm TB or more if your intake has been a restriction.
Old Sep 30, 2008 | 08:06 PM
PSM's Avatar
PSM
haha the problem is pulley down means its turns into a real george forman grill!!!!
Now I'm regreting not getting the 122...
Old Sep 30, 2008 | 09:31 PM
zippy's Avatar
The 90mm when used with the x-link should pick you up about 1psi. The nice thing is that you can run more boost with less blower speed. It's a great mod.
Old Sep 30, 2008 | 09:34 PM
PSM's Avatar
PSM
I think so.. that's why i went ahead and did it before i got the charger installed. I hope this setup is enough power for me. I'm hoping to break into the 13's with this heavy pig. If not, its cam time!
Old Sep 30, 2008 | 09:39 PM
trever1t's Avatar
Didn't 04Denali get into the 12's with his M112...I don't think he had the 90mm eiter.
Old Sep 30, 2008 | 09:42 PM
PSM's Avatar
PSM
yea he did, but I think he had a 2.8 pulley, stall and maybe a cam??
I'd add a smaller pulley but I've heard much smaller than the 3.1 w/o meth just turns the radix into a heater. I don't go to the track enough to warrant the meth.. the time is just for personal satisfaction and maybe soooooome bragging rights
Old Oct 17, 2008 | 11:04 AM
MagnaCharger Rep's Avatar
Banned
Thus generating less heat.....Looks like you contradicted your above statement
