I wanna go fast
Originally Posted by Brian@JPA
this is just my opinion, leave it open for discussion....
A2A will not be as affected by adiabatic efficiency as a W2A, once the water in the W2A system reaches a certain temp, it will not get any cooler.....The A2A is not as affected IMHO......again, open for discussion. No matter HOW big the reservoir you are just running a water heater.
Brian, I see what you are saying, but...
He lives in San Marcos, where its always 75 and sunny.(After noon, anyway). I think that he'll see more benefit from the A2W for a few reasons.
1 - the obvious, race day, that thing sees icewater and effeciency increases.
2 - Water and air are identical, chemically speaking. The difference is that water has more surface area to "expose" when going through the heat exchanger, thereby 'exchanging more heat' than with an A2A situation, theoretically.
3 - Even if #2 is the opposite (due to more surface are retaining more heat than it can cool, in the given amount of time), then there is still the benefit of rpedictability. There will be much less temp. fluctuation in the incoming air charge, due to slower heating/cooling of the water in the system.
#2 and #3 kinda contradict each other a bit, I know. I am not sure which situation I would put my money on, but either way, he'll see the benefit from performance, with the cooler air charge, or tunability, with the narrow temp ranges that the motor will see.
Or I could be totally wrong, and just wasted everyones time.
The A2W came with the kit and I have a meth injection kit to go along with it. The guy I bought it from said that before he had the A2W and meth he would see 180 temps on very hot Texas days but after installing the meth and A2W his temps would stay with in 20 degrees of outside temps.
I have a scan gauge that displays AIT. I will post what kind of temps I am seeing after I get every thing installed and we can compare.
He lives in San Marcos, where its always 75 and sunny.(After noon, anyway). :
2500 - Nice turbo... you know, if you're in to going fast...
Originally Posted by mxhonda97
What part of SM have you been to?? Central Texas summers get Hott!
