I think I hydrolocked my LQ4!
Old Jul 12, 2010 | 11:44 PM
  #21
GMC3's Avatar
dammnn, i hope that nothing is damaged internally and that it is only just hydrolocked. good luck fixing her though, and btw your truck is sick. my goal is to get where your at with your LQ4. except i probably wont get meth inj since it could easily happen to anyone.
Old Jul 13, 2010 | 12:43 AM
  #22
TX Tahoe Z71's Avatar
Sucks to hear man, hope you can make the best of a bad situation.
Old Jul 13, 2010 | 08:00 AM
  #23
silver-mod-o's Avatar
Hunt&Fisherator
pull the spark plugs and spin it over.... do a ccompression check, if something in the bottom end is hurt, you'll have a hole or two with inconsistent compression.... if so, its time for replacement/teardown... and yes, inspect your valvetrain and cam. there shouldnt be anything wrong with them if it was just the bottom end damaged on startup.
Old Jul 13, 2010 | 07:28 PM
  #24
wentbig's Avatar
I have locked 3 or 4 motors, only one bent a rod, 6L Ford Powerjoke.
Pull the plugs, spin the motor. Spray some WD 40 in each plug hole the meth will rust the rings and bore, If it runs warm it up and change the oil fast.
Good Luck
Old Jul 13, 2010 | 07:37 PM
  #25
blown 04's Avatar
That sucks Russ, Id pull the plugs and turn it by hand, if it stops then turn it the other way , if it stops again then more then likely its got a bent one. sometimes you can do more damage using the starter the using a wrench.
Old Jul 13, 2010 | 08:37 PM
  #26
sharpshooter's Avatar
I pulled all the plugs,all were wet and about 3-6 ounces of meth/water poured out of 7 & 8.
I put a ratchet on the crank and it started turning for a while and then stopped hard.I went back and forth and stops in both directions.Then I could hear something inside was broke.
So it is done!
Now I just have to stop thinking all of the I shoulda-coulda-woulda bullshit and get it back on the road.
Old Jul 13, 2010 | 08:43 PM
  #27
ChevyTruck's Avatar
something else
If you need a hand with anything give me a call and I could come down and give a hand if needed.
Old Jul 13, 2010 | 08:46 PM
  #28
thanks RJ
Old Jul 13, 2010 | 09:28 PM
  #29
UBLUZIN03's Avatar
That sucks man!! Do you want that 5.3 block back? haha
Old Jul 13, 2010 | 10:26 PM
  #30
zeake's Avatar
I hate meth. i got off that crap when I sold the whipple.
