I need a 4.5-4" 90* coupler
Old Apr 10, 2011 | 12:21 PM
TURBHOE's Avatar
Default I need a 4.5-4" 90* coupler
Like it says. I need a 4.5"-4" 90* coupler to go from pipe to tb. It's a 90mm edelbrock. The one for the stock tb won't stretch at all. Just to be clear it needs to be 4.5" on the tb side and 4" on the pipe side. And 90* in-between.
Old Apr 10, 2011 | 12:23 PM
Swerve7rpm2000's Avatar
http://www.racepartsolutions.com/products.asp?cat=38
Old Apr 10, 2011 | 03:03 PM
TURBHOE's Avatar
Those are striaght. I need 90* bend.
Old Apr 11, 2011 | 02:34 AM
Revolutionary's Avatar
Have you checked with any big truck diesel suppliers near you? I have had pretty good luck finding stuff in a pinch like that. However if at all possible I would recomend instead of a flexible 90 if you are under boost to run a aluminum or steel elbow and using silicone to couple them. The rubber elbows have a terrible amount of flex to them when you get under pressure and on a design standpoint they are horrible for airflow.
Old Apr 11, 2011 | 03:31 AM
TURBHOE's Avatar
this is actually for N/A. i just posted in here because boosted guys know where to find this stuff for the most part. the stupid intake on this is a striaght pipe with a small curve in it but, its not bent toward the tb. if it were steal i would just weld a bend on it. not to mention he doesn't have e-fans so space is very tight. i'm very frustated at this point. this will be the thing to put the whole build on hold.
Old Apr 11, 2011 | 11:08 AM
THE-HOE's Avatar
I know this is not 4.5 like you said but its the closest I could fine, just posting it up incase it could work somehow. Goodluck
http://intakehoses.com/Merchant2/mer...ry_Code=9DRESQ
Old Apr 11, 2011 | 01:27 PM
krambo's Avatar
check verociousmotorsports dot com
Old Apr 11, 2011 | 05:42 PM
TIM Z's Avatar
11 sec. Truck Mod
silicone intakes dot com.
I bought all my elbows and t bolts from them. They have lots of different transition fittings.
Old Apr 11, 2011 | 10:45 PM
TURBHOE's Avatar
they have a 4.5 to 4.5 90* bend. i may go with that and cut a piece of off the old one to put under the 4.5 on the pipe. its about the only thing i can think of. i found ONE place that had a 4.5 to 4 and it was $90. screw that. lol
Old Apr 12, 2011 | 10:43 AM
PediDr2's Avatar
I know it's frowned upon at times but did you try Home Depot Racer's Supply?
