I Like Boost... My Stock Cats Don't...
Old Aug 21, 2008 | 10:24 PM
  #21
supercharged tahoe ss's Avatar
I run imco 3 inch metal core cats they wont burn all stainless steel in canada we have the sniffer and mine passes
Old Aug 21, 2008 | 11:25 PM
  #22
Wheatley's Avatar
Truck Sponsor
Originally Posted by PSM
I don't know how so many people take out the cats.. I HATE the smell of exhaust on a non cat'd vehicle. Sure for a weekend cruiser, maybe, but on a DD... that would drive me nuts
I love the smell,always have
Old Aug 22, 2008 | 12:01 AM
  #23
SincalT/A's Avatar
I ran a set of 6.0 cats from a 2500 on my setup.The exhaust was routed the same also.No problems getting smogged for me either.I would be willing to bet they hold up pretty good too beings that they were designed to withstand harsh towing conditions.The cats are quite a bit bigger than stock or after market.
Hell I have been toying with the idea of going with the 4" stainless cats that get installed on large kohler generators.
Old Aug 22, 2008 | 01:45 AM
  #24
Whippled2dr's Avatar
Originally Posted by trever1t
STOP!
lol, I have the Magnaflow hi-flow cats and they work fine. Having no cats in CA is good for a $2000 fine plus referee inspections for ever. At least with the Magnaflows you might get by the visual.
BUT
Smelling rich when you are in boost is normal, I mean you are running rich hopefully.
I heard from Rick that the referee stations have been closed due to the California budget crisis, so I believe you just get a fine for now.
http://www.bar.ca.gov/
Old Aug 22, 2008 | 07:37 AM
  #25
trever1t's Avatar
2nd fastest 5.3 ECSB
whooopie!!!! yipeee!! cool, right?
Old Aug 22, 2008 | 09:16 AM
  #26
krambo's Avatar
Originally Posted by Breeze
Another member here showed me some magnaflows that had melted insides and that changed my mind about getting them.
That was Chase I believe. I have some pictures of my 3" metal substrate severe duty cats that melted. They are very similar to random technology.
My new improved design:
Old Aug 22, 2008 | 09:57 AM
  #27
philntx's Avatar
What kind of exhaust temps does it take to melt a converter?
Old Aug 22, 2008 | 10:02 AM
  #28
blue2003ls's Avatar
I like it! It would take a little work since I have the converters welded up to my collector and sweep but it that looks easy enough for now. If it passes the sniffer than I'm good to go... If not I can pick up a set of Magnaflows for a few $.
Old Aug 22, 2008 | 11:24 AM
  #29
trever1t's Avatar
you will not pass emissions without cats....or am i misunderstanding you?
Old Aug 22, 2008 | 01:29 PM
  #30
blue2003ls's Avatar
Not necessarily removing the cats but the inner material and leave the case. With the modern vehicles having better fuel injection, ignition, tuning ect… I am curious about the how much less emissions are present before the cats. Do the catalytic converters really do as much now as they used to. Running WOT or 11.7-12.5 AFR in boost I’m sure they are going to get a work-out but they will probably never see that at the smog check. I’m pretty sure I will be getting the Magnaflow cats but I just want to try some alternatives while I’m going thought the effort of replacing them.
