i just dont get it
Old Dec 20, 2006 | 04:47 PM
  #41
Last Call's Avatar
TOTM: January 2007
Originally Posted by whoopassracer
well again today my iats were about 12*'s over ambient which was 85*'s. not bad compared to the other pulley. and only seeing 150*max and drops quick. all i need is to retune with the 3.1 so i can get more timing. im running dual nozzle with straight water and i bottle of heet and seeing around 7.5-8psi of boost at wot. so is that good, and should i say better than the other fire pulley.
I would run straight meth.
Old Dec 20, 2006 | 04:52 PM
  #42
FarmTruc's Avatar
Performance Trucks Sponsor
Originally Posted by BigTex
Its not uncommon for the IATs to climb really high on a hard run with the small pulley, so I'd say thats normal. However, they temps should start to fall about 10 seconds after you let off the throttle and be within 10* of where you started in a minute or two.
When first reading this, I though you might be adding too much water. Also, if you are maxxing out the 42# injectors, then I'd say you are probably overly rich. You don't have a cam, so your rpms shouldn't be real high. 12* timing is pretty weak for a Radix truck. If its pinging with only 12*, then you definitely have a tune problem. I doubt you are pulling enough air to MAX out the MAF and really didn't need a SD tune. 96 mph trap speeds mean you probably aren't making 350rwhp with the way its running now.
So... I'd fix the pump, get a better tune, and go lighter on the water injection. Keep it simple. SD tune, big injectors, 3 nozzles, etc... are overkill at this point.
How is a truck supposed to run more than 12degs of timing if it's already pinging and the a/f ratio is fine??? The truck was running 13psi, which is too much for the Radix, so 12degs if fine. It's not a tune problem. Max timing was achieved, a/f ratio was setup and that's all you can do.
"really didn't need a SD tune" why is that? SD tunes pull smoother, have better control over a/f ratio, and the computer actually understands boost, so it's a better tune for forced induction. My truck dropped .3 tenths going sd tune, so they do work! What's your reason, have you done any sd tuning?
Get a better tune? Max timing and good a/f was set.
Thanks for the input,
allen
Old Dec 20, 2006 | 05:46 PM
  #43
BigTex's Avatar
Yes I have used speed density tuning. My statement was basically saying to keep it simple. Obviously his truck isn't running worth a darn and its obvious he is looking for some help. I'm just offering him some assistance. Here is some more:
If the tune is not the problem.... Then I suggest that he finds a good performance shop that will help him really figure out his problem.
Old Dec 20, 2006 | 06:04 PM
  #44
whoopassracer's Avatar
well big tex my truck runs fine now thanx to allens opinions and others(thanx guys) and i wouldnt take it to any other shop but his. he's the one i'll deal with and in future mods he'll be the one installing when im schedualed for it. the way my truck is running now its' good. i'll be going to neslons sometime in january for a retune.
Old Dec 20, 2006 | 06:07 PM
  #45
BigTex's Avatar
I'm glad you are happy. Too bad you didn't go get allen's opinions first before starting this thread. We all thought you had problems and were asking for help.
Old Dec 20, 2006 | 06:19 PM
  #46
FarmTruc's Avatar
Old Dec 20, 2006 | 08:05 PM
  #47
XLR8NSS's Avatar
Adkoonerstrator
Hang on whoopassracer, BigTex was just offering some suggestions to try and help. His post was not a dig at you or anyone else.
One way to trouble shoot something is to go back to basics and start over. That's what he is talking about by keeping it simple.
Honestly it sounds like your truck is running about what it should with 7.5-8psi on a 5.3L ECSB in the heat. In decent weather, with a 6.0L, a little more weight, and about the same boost I only ran slightly faster than your recent times.
What was your setup and when did you run the times in your sig?
Old Dec 20, 2006 | 08:14 PM
  #48
i ran this time at spokane raceway park in spokane, washington, weather was like about 50*'s and i had everything except tbstall and 28's slicks. and not sdtune.
have radix with i/c and 2.75pulley tuned with allen nelson
edelbrock shorty headers
43lb's injectors 4:10's
tansgo reprogramming shift kit with Z-Pak clutches
80mm tb,160*stat, electric fans
and 26 et streets
Old Dec 20, 2006 | 08:19 PM
  #49
XLR8NSS's Avatar
Adkoonerstrator
Do you think it could be your transmission or stall converter going bad?
Old Dec 20, 2006 | 08:23 PM
  #50
now see thats what im thinking ever since i install the tb stall my mph went down, im thinking of going going back to stock stall and 26inch slicks, and the best time with the tbstall and 28's is a 13.05@101 does that sound right with same 50*'s temp
