i just dont get it
Old Dec 16, 2006 | 01:38 PM
whoopassracer's Avatar
im running just washer fluid no heet with the 3.1(9lbs) and 2.75(13lbs)pulley and well i have to sets of slicks both 28x11.5x15 on set are hoosiers drags and the other are et streets i do a bit better with hoosiers but not much maybe .04 thats it. dont know at this point meth isnt working along with the sd tune. i started noticing once i change the stock stall to tbstall and 26's slicks to 28's im losing top end for some odd damn reason i cant get more than 96-97mph tops. i mean im sd tune and 2.75pulley my timing is at 12 do to audible ping so maybe with the 3.1 and more timing but still think i wont run what i want to run. but at this time its pointless to even run untill i know whats wrong.
Old Dec 17, 2006 | 03:34 PM
TahoeSS01's Avatar
Build a intercooler setup for it, you break that 14 sec barrier for sure.
I has meth and now I am running dry shot as a cooler,still the same.Alot of other mods on truck that is why,as other suggested, I also need HP tuners to find it and fix it.
Thanks 03slt
Old Dec 17, 2006 | 04:34 PM
ogkevin13's Avatar
Banned
seems like a diff tune will be the answer
Old Dec 17, 2006 | 06:08 PM
Whippled 496's Avatar
ditto that.
Old Dec 17, 2006 | 08:38 PM
i dont see why guys with radix,cam,meth and 3.1pulley's are running up in the 20*'s of timing and up in the high 90%'s injector DC with 42lb's, which for me i dont have a cam and their iats' are waaaaaaay lower than mine are i put the 3.1pulley and at wot i saw 150*'s iats and timing at 12, but not retune for the 3.1 and would think that having a cam would generate more heat. i just dont f$#ken get it. so if i put the gt2-3cam and 3.1pulley im i going to see timing up in the 20's also. and what would my dc on 42lb injector's be at with the 3.1 with, 2.75 im at 100%dc
Old Dec 17, 2006 | 08:50 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
A cam is just going to make you IDC even worse. What those guys are doing is relying ont eh meth to add fuel. Time to go to 60# injectors or just ditch the radix and throw an N/A cam in it and run 13.2s like AP2002 did with a 5.3 in his ECSB with a heavy *** bed cover.
Old Dec 17, 2006 | 09:09 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I did a run 2 nights ago. I ran it up to 88mph (No time travel)
My IAT topped out at 131*F
My timing was 17.5* (Thats the max I have it set at)
RPM was 5900 @ 91% IDC (42# Green tops) just prior to the 2-3 upshift
Within 1 minute my IAT had dropped from 131* to 108*
Outside temp was 60*
Old Dec 17, 2006 | 09:16 PM
thats just it they are just using water to cool the intake charge no fuel additives. so by putting the cam and 3.1 i will still need injectors.
Old Dec 17, 2006 | 09:30 PM
1slow01Z71's Avatar
You need to put straight methanol in there, it is combustible and will supplement the fuel that comes form teh injectors. Wilde Racing is hitting 11.40s on 42#ers but he has two meth nozzle at full blast to help fuel his motor.
Old Dec 17, 2006 | 09:36 PM
well i have 3 nozzles on mine setup i need fuel but yet need to cool the intake temps
