How much should i worry about my boost spikes?
Old Aug 11, 2013 | 12:21 PM
kelsey_canard's Avatar
Default How much should i worry about my boost spikes?
I'm wanting to turn the boost up on my truck. Currently I'm on 93 octane only. Going to be ordering a manual boost controller. Right now I'm running on the 4psi waste gate spring. I'm getting boost spikes when it shifts gears. A spike to 6psi in 1-2, and a spike of 8psi going 2-3. Should I worry about this causing detonation? Anyone think they will clear up? How do I go about all this turbo nonsense?
Old Aug 11, 2013 | 12:28 PM
Atomic's Avatar
I have a gauge for that
no you will be fine. Here's a secret boost pressure doesn't blow up engines, mass flow rate from the compressor does
Old Aug 11, 2013 | 12:59 PM
This sounds like a big mathematical formula is coming. Where are the broad blanket statements? You should be able to calculate mass flow rate from the compressor using the compressor map, correct? What are the tolerences? Shed a little light here. I'm all ears.
Old Aug 11, 2013 | 01:18 PM
Atomic's Avatar
the independent axes on the compressor map is exactly mass flow rate. So just find your pressure ratio and there you go
Old Aug 15, 2013 | 11:02 PM
Got her turned up a bit. She floats around 6.5psi to 7.5psi. Feels like a whole new truck. Although, the spikes persist. Just trying to get a safe tune on my truck if you don't care to take a look. Here a screen shot, and I'll also post a log and config. Still running pig rich.
Chavette
Oct 28, 2015 07:33 PM
1slwgto
Oct 1, 2015 01:51 PM
scooter k
Sep 16, 2015 10:32 PM
JordanH
Sep 12, 2015 12:02 AM
jtphelps289
Sep 11, 2015 06:37 PM
