how much power 317 heads
Old Jan 11, 2015 | 12:15 AM
RickLowpez's Avatar
Default how much power 317 heads
how far can I go on stock 317 heads on a boosted 364?is there a point where stock vales etc get maxed out?
Old Jan 11, 2015 | 12:19 AM
gamble686's Avatar
Nope not really.
Old Jan 11, 2015 | 10:15 AM
George C....'s Avatar
Formerly ScreamingL
there is a point but will you find it with your build? probably not
Old Jan 11, 2015 | 10:31 AM
A lot more power than you can hook to the street......
Good valves (keep stock or go slightly larger) and a GOOD valve job are all that is really needed.
Old Jan 11, 2015 | 10:43 AM
dirt track racer 81's Avatar
Big chief made over 1000 with stock 317 heads.
Old Jan 11, 2015 | 04:43 PM
Rootbeer02's Avatar
my buddy has gone deep 9's on 317's
Old Jan 11, 2015 | 08:29 PM
LPCWS6's Avatar
I know I'm not setting any records but I'm happy with my 708rwhp on AI ported 317's on my stock LQ9 short block.
Old Jan 11, 2015 | 08:37 PM
Formerly ScreamingL
now you can have a set ported which will always make more power but if your wallet doesnt allow it then move onto next item
sloppy boyss one car went 7s at 2800lbs with a set of 317s
Old Jan 12, 2015 | 05:09 PM
Vortec350ss's Avatar
I know I am nowhere near it... but I'm also not worried about it. I run 15PSI through a cam only LQ9. I don't hit that often, but I have done it. Typically I run it at a max of 13#.
Old Jan 19, 2015 | 09:18 AM
black6spdz's Avatar
I have stock casting 317s on my truck and I am pretty sure I am north of 1k horsepower. I had them cleaned and a valve job done that was it. Not sure what type of FI you are using but I think money is better spent elsewhere in most cases.
