how much boost is safe
Old Jun 10, 2009 | 07:26 PM
avalanchett's Avatar
Default how much boost is safe
how much boost is safe on a stock 5.3 chevrolet. i have 8 on it is that ok or too much ? can i add more boost?
thanks for help guys ..
Old Jun 10, 2009 | 07:54 PM
charcold-bowtie's Avatar
theres a lot of factors.... My opinion is around 12ish. With meth. At least daily driven. I could see around 14ish at the track with a good tune.
Old Jun 10, 2009 | 07:56 PM
Mr. Sandog's Avatar
What I've heard from the people I respect is 10psi max, with a good tune, sustained over time.
Old Jun 10, 2009 | 07:59 PM
nonnieselman's Avatar
Tune is the major factor. but it depends on how you use the truck.
Parish and that bunch have been punishing the stock 5.3 in the Fairmont for quite some time on 18#? boost but they are running race gas.
Old Jun 10, 2009 | 08:13 PM
Mangled03gmc's Avatar
Baltimore Whore
You could run 10-12 psi safe.. Like mentioned the more boost you run the more spot on the tune has to be... The tune plays the biggest rule..
Old Jun 10, 2009 | 09:10 PM
stock48's Avatar
9 Second Truck Club
The only true way to tell is keep adding boost until it blows up, then fix it and back it off a little. Or take my approach and build it back stronger, and try to blow it up again
Seriously though every application is different. In a light car, with a loose converter you might get away with 18~20PSI for a while. In a heavy truck 14~16 PSI might be the limit.
The tune, fuel quality, temp, and back PSI are your main factors.
thanks guys i am running 9 psi making 450 to wheels with 14 timing.. so this is saffe?
Old Jun 10, 2009 | 09:12 PM
What are you calling Back PSI?
Old Jun 10, 2009 | 09:33 PM
back presssure from the exhaust.
Old Jun 10, 2009 | 09:34 PM
Thats what i thought, had to make sure tho.
