How Much Boost Can It Handle
Old Jan 16, 2011 | 05:31 PM
OutOfLineKid's Avatar
Default How Much Boost Can It Handle
How Much Turbo Boost Can A Stock Ls1 Handle Without Making Major Upgrades To The Motor
Old Jan 16, 2011 | 05:34 PM
Mangled03gmc's Avatar
Baltimore Whore
10psi no problem but keep the tune where it needs to be.. More then that if you keep the timing, fuel in check...
Old Jan 16, 2011 | 07:47 PM
Ok Thanks Im Thinking Of Getting A Ls1 Motor and Want To Go Turbo.
Old Jan 16, 2011 | 07:51 PM
charcoal03silvy's Avatar
Get a KB racing kit or trick!
Old Jan 20, 2011 | 11:01 PM
Pwebbz28's Avatar
Its not the boost the motor cant handle its the power it makes. Most people keep it under 600 at the wheels on stock internals. This IS on an F body drivetrain though. The stock crank can handle quite a bit (around 900)as can the rods (around 700) , the pistons are what give!
Even if you produce 20lbs of boost, if it only makes 500hp your fine.
Old Jan 21, 2011 | 06:44 AM
Banned
keep the detonation out of the motor and 600-650rwhp is possible, a buddy of mine has a ls6 making 750-800rwhp for the past year with no issues. thats supercharged and a 100 shot of nitrous
Old Jan 21, 2011 | 11:06 AM
smokeshow's Avatar
Mod with training wheels
Keep in mind that the stresses on the crank/rods/pistons internal to the engine are the same on any forced induction per given amount of boost. A blower can draw a considerable amount of power off of the crank. That power doesn't show up as flywheel hp because the power is gone before it ever hits the dyno, but the internal stress is still there.
Old Jan 22, 2011 | 01:20 PM
So its better If I reinforce the motor with better internals and all that good stuff. Thanks for the Info
lucas287
31
Jan 12, 2021 06:18 AM
FlyingLow
Nov 24, 2015 10:05 AM
rumblebox
Oct 29, 2015 10:35 AM
2500ZL1
Sep 12, 2015 03:50 PM
chvy=power
Sep 8, 2015 11:06 AM
