How high to spin engine w/ Radix?
Old Mar 29, 2007 | 08:28 PM
Default How high to spin engine w/ Radix?
How high can you and should you spin a 5.3L with a Radix? Right now I am shifting at 6300rpms, is that ok to keep?
Old Mar 29, 2007 | 08:48 PM
dewmanshu's Avatar
Moderately Differentiated
what pulley size? springs? cam? UD pulley?
Old Mar 29, 2007 | 09:09 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Where do you make peak HP/TQ?
I spin mine to ~6300, my HP starts to fall off over 6050 and I make peak tq ~4200
Old Mar 29, 2007 | 09:21 PM
BigTex's Avatar
If you get a dyno done, make sure you pull past the point where you normally shift. Look it over and find the range where power stops gaining and begins to drop. Ideally, you'd find the rpm level where power really falls off and base your shifts on that. You want the most power delivered to the wheels that you can get and you want to stay in that sweet spot as long as possible.
I had 6300 rpm shifts with a 2.75" radix pulley on my SS, which put it way out of its efficiency range. A 5.3 shouldn't have that problem.
Old Mar 29, 2007 | 09:22 PM
I have shifted at 7000rpm with a 2.75" pulley when I was running the bigger cam in the 402.I doubt you will hurt the supercharger,shift at an rpm where you are making power,6300 should be about the max with a stock cam.
Old Mar 29, 2007 | 10:28 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by BigTex
I had 6300 rpm shifts with a 2.75" radix pulley .
Me too. IATs are through the roof though.
Old Mar 29, 2007 | 10:48 PM
CHarris's Avatar
I'd start to wonder about springs, too. I shifted at 6300 with my 2.75 pulley regularly but I had a cam and valve springs.
Old Mar 29, 2007 | 10:53 PM
Wilde Racing's Avatar
How do I change this text
Dang you guys are turning some RPM, I keep trying to get Dewmanshu to try shifting at 5,500 like real men do....
Old Mar 29, 2007 | 10:59 PM
nightrunner's Avatar
Mr. Obvious
not sure on his setup cam wise but my stocker quits pulling around 5500rpm
Old Mar 29, 2007 | 11:24 PM
parish8's Avatar
single digit dreamer
i always use my gtech to help me decide when to shift. it is real easy to use. you want to maximize your g's thru the run. the g's before and after the shift should be real close to the same. if there is a big jump in g's after the shift then you are shifting too high. if there is a big drop in g's then you are shifting too soon. easy as that.
here is a chart of a stock truck with stock shift points.
the et's dont mean much here since the launchs were all diferent but you can clearly see the shifts and the drop in g forces. if the shift was held off longer the average g forces would be higher and the et quicker. you can see on the black run where we held it in 2nd at the top and how the g's are a little higher. the 1-2 shift would be the same if it was shifted higher.
it's a sweet tool(toy).
