How to determine turbo size...tt setup
Old Jun 23, 2007 | 11:42 PM
Hawk179's Avatar
Originally Posted by wondertruck
thanks for the info Rick, great stuff. I'm running solid roller and a victor jr. manifold.
Even the big cube truck we are building, I would not have gone that route. ITs a tough idea to use that manifold for most of the apps. It sounds great and such, but alot of things have to change for that style of runner. How does it run for you?
RIck
Old Jun 24, 2007 | 03:49 PM
wondertruck's Avatar
Banned
vic. jr= total loss of low end torque over stock manifold (on motor) below ~3700-4000rpm. Above that it does feel like it pulls a ton harder. I need to have another set of heads done with the Vic. in mind. The heads I have now are just a set of stage 1.5 TSP heads that were designed for a stock manifold.
Old Jul 17, 2007 | 10:06 AM
Hawk179's Avatar
what you lack on the bottom, you better have double that on top to catch back up to where you could have been.
R
Old Jul 17, 2007 | 10:31 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
R
I like that quote -- and it works for so many different kinds of conversations lol
Old Jul 17, 2007 | 11:51 AM
Hawk179's Avatar
NICE!!!!.
R
Old Jul 18, 2007 | 10:22 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
I'm running a 370, ~4250# range, not a track only thing however it shall run like it is. A single 76 would probably be nice on it, I want to stay with the larger frame so I can upgrade later if I want. A friend nas an S88 that has been modded to 91mm, thought about building the kit using that as a mockup, and then going with the same frame 76mm. I would like to see ~750rwhp with a mild setup not pushing to hard.
Our S88's are no joke, and the S91's are going to be plain sick.
When choosing a proper turbo, if you want it done correctly, you will need more then just the consumption chart and compressor map.
Last edited by trever1t; Jul 18, 2007 at 10:58 PM. Reason: non-sponsor link removed
mhorn0817
Jul 8, 2017 01:54 AM
shupe
Aug 5, 2015 06:45 PM
MWRitter
Jul 27, 2015 09:41 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
