Hooking up a boost safety on an LSA
Old Aug 15, 2022 | 11:23 AM
Modern Barbarian's Avatar
Default Hooking up a boost safety on an LSA
Anybody ever hooked up a boost safety on an lsa supercharger? I have the innovate psb-1 that can activate a boost safety and was wondering if anyone had done it before.
Old Aug 15, 2022 | 07:20 PM
terravast4's Avatar
what is a boost safety?
Old Aug 15, 2022 | 08:07 PM
smokinlmm's Avatar
Pulls boost if afr is off. I think it's more for high boost. I just run a good fuel regulator and 2 pumps and don't worry.
Old Aug 16, 2022 | 02:37 AM
Atomic's Avatar
I have a gauge for that
You could use a Mac valve wastegate solenoid on the bypass actuator line if you wanted to.
Old Aug 17, 2022 | 01:21 PM
Lt1z383's Avatar
I have done it on the lt4 for some customers I tune for as it has a factory abuse valve so double port. We used the aem flow valve on methanol so that if the meth doesn’t flow it will open the bypass. I have an lsa on my 07 Tahoe but have not looked at it or the bypass in a while to see if can work on that or not. 200k on the motor now over 70k with boost and still kicking. Lol I have run it pretty lean a few times and yet to hurt this 5.3. I’m 10 psi minimum and sometimes on 14 psi with it depends on pulley I’m running. Been towing my boat so it’s on low boost at moment.
Old Aug 17, 2022 | 01:40 PM
Probably going to just skip it. Doesn't seem necessary in this set up
Rick_Vor
Nov 24, 2010 04:23 PM
fastjweb
Jun 7, 2010 07:47 PM
slowlsx
Sep 21, 2009 11:36 PM
02Vortech
Sep 26, 2006 10:02 PM
southern_chevy
Apr 30, 2006 10:52 PM
