Hooking up a boost controller to wastegate
Old Dec 25, 2012 | 02:50 PM
chevyboy.520's Avatar
Default Hooking up a boost controller to wastegate
How are you guys hooking up a reference line to the wastegate with a boost controller? I've heard couple diff ways.
So I looked it up on jgs website and found these diagrams
1.with out a controller
2.with manual boost controller
3. With high end boost controller? Not sure what's different between a std boost controller and this
When I started out a just ran a reference line from boost controller to the single port on the wastegate and left the second one left to air. Like in diagram 1
I was wondering if I should change it and go with it like its illustrated in diagram 2
So lets see how everyone does it
Old Dec 25, 2012 | 02:57 PM
smokeshow's Avatar
Mod with training wheels
My new setup will have both sides of the gate routed through the boost solenoid but controlled independently. Allows to run a minimum of spring pressure and a max of whatever boost the turbos can make.
Old Dec 25, 2012 | 03:11 PM
So hooking up my controller to both ports like diagram 2 will change what? Compared toe running a controller hooked to just the one port on diagram one....
Old Dec 25, 2012 | 03:17 PM
smokeshow's Avatar
Well, my new one is an electronic boost controller that runs a 4 port solenoid. So its a little more complicated.
Old Dec 25, 2012 | 03:27 PM
Nice! Which one did you get?
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
Razor
Aug 16, 2015 11:39 PM
lxcoupe
Jul 15, 2015 10:03 PM
