Home Brew STS
#21
Originally Posted by 44newman
I have started gathering parts but I havent started fabricating yet. And I do know about the bigger injectors, and a good tune. I dont think I will tig weld it, I mean even a NASCAR chassis is mig welded, Id save the tig for stainless and aluminum. I will use aluminized pipe though. And Iv heard of guys calling STS on a pipe only kit and they still wanted $2k, just for the pipe and couplers, granted it HPC coated. Just think what youd pay for a custom exhaust, from the manifold to the tailpipe, beside using couplers instead of welding every section its not to far off. But dont get me wrong there is a lot of little stuff to contend with, oiling, pcv, wastegate, wiring, relays, and so on.
Anyways, has anyone out there ever muffled a STS setup?
Thanks Jeremy
Thanks Jeremy
#23
Also you might not want to weld up the all the pipes. There are couplers there for a reason. It would make install pretty damn difficult for some of the pipes.
#26
Make sure you get the crankcase ventilated properly to prevent presuure build up in there.
I just checked my STS ventilation doo-hicky and the filter was soaked with oil and burped all over my intake pipe, couplers, and MAF!!
I looked under the return cap to find some more mily crap in the oil, I just changed two weeks ago.
Sorry for whoring the thread a little, just want to stress don't forget anything in the set up. Ask anyone here with an STS and I'm sure they will be glad to give you input.
#27
Hey thanks, If you have ever been to junkyardturbo forum, a guy called dino has done a rear mt allready. Now hes moved the turbo to the in front of the radiator, its a sweet setup but hes not the best welder. But his pcv check valve seems to work great.
This is a guy I knows sprint boat, is that bad *** or what?
Thanks Jeremy[IMG]
[/IMG]
Thanks Jeremy[IMG]
[/IMG]
[/IMG]
