Hit the rollers......
The dyno was just to justify it was making power.I just rolled it off the street and made some pulls without touching the tune.The bad affect was that it started to heat soak the inlet temp sensor and pulled timing.On the street the truck runs 2-4 degree's more timing and holds 12lbs no problem on pump gas,well it does spin 1st/2nd at WOT.
We will hit the track and show what it does.There is way to many people on here that try to push high dyno #'s then run crappy track times.We'll go with low dyno #'s and fast track times
