High IATs - Causes and solutions?
Old Sep 13, 2007 | 08:43 AM
  #91
dhpro's Avatar
Originally Posted by Holty
Have you tried just simply replacing the IAT sensor to be sure its not the problem?
Nope...prob worth checkin tho...u never know!
I really appreciate all the brainstorming guys ! As I mentioned earlier, I'm gonna drive it for a about a month as is and head back up to Slowhawk for an update. At that point we'll have done a little more R&D (altho Grippy will prob still be on jackstands!) the weather will be nice and cool (40's & 50's ) and we'll do some cam & pulley combination work. In the meantime maybe someone else will get one of these running and we can get some comparative notes exchanged. R/
Old Sep 13, 2007 | 02:30 PM
  #92
dhpro's Avatar
Here's the Dyno file
File Type: pdf
Old Sep 13, 2007 | 02:41 PM
  #93
moregrip's Avatar
what a rush!
ahem, I've never been on jackstands
Old Sep 13, 2007 | 02:47 PM
  #94
dhpro's Avatar
By the time ur runnin I'll have gone TURBO!
Old Sep 13, 2007 | 02:53 PM
  #95
moregrip's Avatar
what a rush!
sure sounds like it
Old Sep 13, 2007 | 02:58 PM
  #96
krambo's Avatar
Looking at your graph, your TQ and HP #'s fall off pretty early during the pull. I know it is obvious , but it is a sure sign of High IAT's and or pulled spark (among othere things). How was your boost #'s / MAP during the pull (especially over 5K)?
...following this thread, great discussion.
Old Sep 13, 2007 | 04:01 PM
  #97
Last Call's Avatar
TOTM: January 2007
I agree, your numers do fall off pretty hard after 5k.. Here is a copy of my graph with a 6.0/4l80/2.9 pulley/alky kit/90mm upgrade.
I think I would go to a larger pulley and try more timing.
Old Sep 13, 2007 | 05:39 PM
  #98
moregrip's Avatar
what a rush!
yep, not the typical magnuson dyno graph, something isn't right, have you looked into the tune? might want to double check that
Old Sep 13, 2007 | 05:56 PM
  #99
Slowhawk's Avatar
LS1Tech Sponsor
Nothing wrong with the tune.I spent alot of time on it.11.5-1 A/F across the board. 11-12lbs of boost. 18-14 degree's of timing following heat.
Here is what I see
Blower is running too friggin hot,probly overspun since 8lbs made the same power but about 40-50 degree's cooler which we bould run 18-20degree's of timing.This run started at 140 intake temp and ended at 184 intake temp.
The biggest thing is that the motor combo probly just isn't right.Maybe the Cam was put in with way too much advance or something.
Also a note- when we got the truck is had way too much timing and A/F was at 12.5-1.The timing was at 24-26 degree's and pinging like a ***** which left a nice smoke cloud behind it at WOT.(rings fluttering from too much timing advance)Also 2 cylinder were not firing due to burn't wires.
I'm sure if we get our hands on it this winter we can get the power with a correct Cam/compression setup.Another thing to look at id the Cats,they could of collapsed under the old tune.
Old Sep 13, 2007 | 05:59 PM
  #100
moregrip's Avatar
what a rush!
Here is what I see
......I was going to mention the cats as well, and at this point I'd check them just to be safe side, I surely wouldn't want to be driving my truck around for a month with jacked up cats.
