High iat?
Old Apr 14, 2009 | 09:55 AM
  #21
NORCAL TBSS's Avatar
Restricted User
lol for some reason thought you were in the city also. Sorry
Old Apr 14, 2009 | 09:56 AM
  #22
Restricted User
reason i did the bigger tank was my cobra buddys worked for them and worked for me. Also helps to relocate the battery to right rear area for traction.
Old Apr 14, 2009 | 09:57 AM
  #23
03tahoe22's Avatar
Wishing I was in Texas or Cali..... that seems to be where all the action is!
From a cost stand point:
Canton is like $250
Heat Exchanger ?$ and two fans $80
Meth stage II $700
Old Apr 14, 2009 | 10:02 AM
  #24
Restricted User
i mean id upgrade the heat exchanger first. joe from left coast 32 makes a dual heat exchanger its bad ***
Old Apr 14, 2009 | 10:09 AM
  #25
hellbents10's Avatar
LS1Tech Sponsor
I would upgrade the heat exchanger first also. Your biggest benefit will be from having the proper size heat exchanger and having the correct flow through it. By the time you get a bigger exchanger on it your capacity will also increase.
Old Apr 14, 2009 | 11:28 AM
  #26
vanillagorilla's Avatar
I agree with BigTex, a larger reservoir is only beneficial if your chilling it, although the stock Radix HX is pretty damned dinky. On the street a larger reservoir will just take longer to reach steady state. If you're going to increase the capacity for a street setup, its best to have it in the heat exhanger. You get increased heat removal and more capacity.
Old Apr 14, 2009 | 11:48 AM
  #27
Whippled 496's Avatar
This one helped out my temps alot if you can make it fit.
https://www.performancetrucks.net/fo...d.php?t=385387
madmann26
Apr 29, 2020 09:17 AM
smok'nZ
Oct 6, 2015 01:14 PM
JordanH
Oct 3, 2015 03:59 PM
carid
Oct 1, 2015 09:22 AM
Slammed silverado
Sep 28, 2015 06:14 PM
