high boost on low or low boost on high !!
I've heard both ways.....
But most will likely say low comp eng + high boost = faster....
More air and fuel in the cylinder to light off = more power..
Now for everyday driving and a wide power band high comp eng + boost = drivability..
What I don't understand is the fact everyone says "Nitrous Loves compression" What the hell is the differents between boost and nitrous besides IAT's?
The reason you dont understand it is because its false. I would not put nitrous on a high compression motor. It does run good on more compression, but you will have to treat it like boost. So if the compression is modest, then it will run good. But i would not build a nitrous setup with lots of compression.
R
(If you just add extra oxygen to the system without any additional fuel it would go extremely lean)
Takes both.
How do I change this text
R
R
