Help selecting new rear gear ratio...
Same truck, new question.
RCSB turbo 4.8, 4l60, 3200 Circle D and 4.10 gears. Truck makes ~540hp/590tq @ tire.
Truck is insane, wants to spin and swap ends @ <40 throttle just rolling into it.
I was thinking 3.73 wouldn't help so, 3.42 or a 3.55??
What are some of your set-ups and what would you have done different?? (I have a 32" x 11 3/4" Drag radial on order to help the situation (305/50r20)).
Quick Performance is going to change out my gear choice (I bought a 3.90) for free if I just tell them what I want.
It might be living because you can't hook up
Once you can get the power down, the trans may not live a happy life. But hey, I still have a 4L60 in my truck too, so I can't hate on it too bad
Turbo's like load, so the higher the ratio, the better. Is this a 1/4 mi or roll truck?
If you want a strict suggestion without much thought, 3.23's and up the boost if you need to
Try the drag radials before changing the gear. The 4.10 gears are going make the 4.8 fell better out of boost and will be a little more responsive getting into boost. The 4l80 recommendation and pertaining traction comment also have merit once the DRs are fitted. A taller gear will also load the converter more thus making it feel looser when not locked up.
Turbo's like load, so the higher the ration, the better. Is this a 1/4 mi or roll truck?
Doug posted this Tech Tip Tuesday this week.
The Nova sitting behind him lost an engine during RMRW last week, got into the oil and slammed into the wall at the top end of the racetrack.
How to choose the correct gear ratio for a Turbo Car
Nova in the wall
Nova in the wall
^^Good vid and I agree. Maybe I should stick with the 4.10 until I get the new tires and see how much it does or does not improve the situation. I am currently searching for traction on the street. Sand bags may be in order...
