heatexchanger cooling ideas
i addeed extra heat xchanger came from a forklift machine its bigger than stock radix heat xchanger my IAT still high..
do you think if i rout my 2 windshild water hoses to the heat exchangers to sqirt on them will it help to lower iat... or anyone have better idea
but what if you use the windshield washer reservoir then squirt mist on the xchanger is it effective.. i see its a very easy to do thats what i like about it
sometimes its crazy in summer time when the temperature is 50deg i see around 170-180F after the 2.7 pulley and lower timing
i just put new large xchanger under the pumper and it dropped my iat very little i was very surprised it didnt lower the temp much more...
have you tried any of the fluid additives? Like Water Wetter,or Purple Ice they have been proven to reduce temps as much as 20*in some applications over antifreeze,I have used both radix current design H/e upper stock location and behind the bumper along with distilled water and Purple Ice 50/50 mix,my Iat's never went over 160 on hot summer days in the 90+* days.
i used waterwetter before in my radiator i didnt feel any difference so didnt think about it....
rite now im using 100% distiled water with nothing else do you think 10 or 20% antifreeze with water will lower the temp??
Maybe a fluidyne H/X and some minifans? I think Grippy did that....or someone did it.....i think that helped.
Your IC will only remove X amount of heat from the air temps it is only so big.. The only way to make it better if the other parts are up to snuff, is to make the water colder. Ice tank but that is only good for drag racing.
Spraying your heatexchangers with water will let them pull more heat from the water but that does not mean it will help your air temps...
Water/ water/meth or nitrous injections any of these options will greatly decrease your air temps.
