heads and cam picked out need other parts info
Old Feb 13, 2014 | 02:59 PM
stroker87's Avatar
Default heads,cam & injectors ordered need other parts info (Help please) 2.0v
Edit:not to start a new topic just reworking this one
this is all for a lq4 turbo build in my 2004 silverado
I have a set of 317's CNC'd then hand polished, triple 12 cam and Siemens Deka 60# injectors all coming in this week
this is part numbers I came up with from serching on line just want to make sure this stuff will fit my 01 lq4
Gm LS-Series engines lifters LS7 P/N 12499225
GM 6.2L MLS (7 Layer) LS9 Cylinder Head Gasket.4.100" Gasket Bore
.051" Compressed P/N 12622033
GM Performance Parts HD Timing Chain LS9, LS7, LS3, LS2, LS1 & LS6 P/N 12586482
all the above stuff work in for my build?
still would like more info on oil pump and push rods
lq4 10 to 12# boost probably meth too,
Old Feb 13, 2014 | 03:07 PM
oakley6575's Avatar
Roller lifters - BTR Slow Leakdown Lifters
what injectors? (60's? 80's?) plug type? 60's would probably suffice
timing set Stock will be fine with ls2 timing chain
head gaskets LS9 gaskets would be bulletproof for your needs
oil pump stock or L76 pump for a bit more pressure
Old Feb 13, 2014 | 07:54 PM
stroker87's Avatar
so stock gears with the ls2 chain?
any thing extra needed to run L76 oil pump?
what type of connector for the injectors?
Old Feb 13, 2014 | 08:43 PM
gamble686's Avatar
Connector won't really matter you will just need pigtails for your harness.
Old Feb 13, 2014 | 09:22 PM
stroker87's Avatar
yeah i know that but if i can just get plug and play injectors why not.....
Old Feb 14, 2014 | 07:31 AM
6.0l RST's Avatar
then look fo rmultimeter plug injectors thats what you have but if you do ev1 or ev6 plug pigtail you will have a world of options
Old Feb 14, 2014 | 03:36 PM
stroker87's Avatar
ok that make sense now
Old Feb 23, 2014 | 06:51 PM
stroker87's Avatar
trying to order injectors and a fuel pump dont know the part numbers ......
her some have trubble with the O rings being the wrong size and having a fitment issue just trying to make sure i get the correct ones seen so many to night got my head spinning short long 3 hole 4 hole patterns
Old Feb 23, 2014 | 07:09 PM
9 Second Club
Buy injectors once. Get the 80's.
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
Aboss
Jul 9, 2015 10:28 AM
