Header studs
Old Sep 23, 2015 | 08:14 PM
GMCtrk's Avatar
I did the v6 studs years ago
Have a machine shop belt sand the flange flat. It will likely warp again, just the nature of the beast. Use only GM MLS gasket and no silicone.
Old Sep 24, 2015 | 09:29 AM
smokeshow's Avatar
Mod with training wheels
Originally Posted by GRRR65GTO
Yeah I figured the flange is warped but what can you do to fix it get it machined? Wont it just warp again?
I thought about using silicone but then I have to worry about scraping the surfaces clean after, thats why I liked the factory gaskets
Yeah it will warp again. I've had to mill them a few times. Need to get Kyle on that 1/2" flange bandwagon lol.
Old Sep 24, 2015 | 10:05 AM
Vortec350ss's Avatar
Dorman - Help Exhaust Stud Kit - M10-1.5 x 62mm 03142: Advance Auto Parts
these show on certain sites as a factory replacement for the GM 6cyl
M10 x 1.5. Is that what will work with our trucks?
Old Sep 24, 2015 | 11:38 AM
kbracing96's Avatar
They will move around bit from time to time., like Jake said, nature of the beast going from cold to very HOT 1000's of times! I belt sand them before they leave the shop but have just used a big file on them before too. MS files pretty easy and it shows you the high spots right away.
Old Sep 24, 2015 | 11:48 AM
GRRR65GTO's Avatar
I think those are the right thread and size Rob. I might go pick those up, I only have issues with the turbo manifold so I was only gonna put studs on that side for the moment anyways. The only thing I wonder is are they gonna bottom out in the cylinder head before they run out of threads?
I just got these in yesterday I hope they'll solve my problem.
Yes that is one gasket...
I had a friend put some on his 350 in his square body on a ancient set of cheap headers that are probably very warped and no leaks yet....
Old Sep 24, 2015 | 05:39 PM
GMCtrk's Avatar
Never use anything dorman.
Old Sep 24, 2015 | 06:00 PM
JordanH's Avatar
Restricted
Where did you pick that gasket up at?
Old Sep 24, 2015 | 06:49 PM
BlackGMC's Avatar
Resident Retard
Check out remflex gaskets. They are pretty thick and the compress. I used them all over the place on my turbo.
Old Sep 24, 2015 | 07:20 PM
JordanH's Avatar
Restricted
Just checked them out, seem pretty legit! Im gonna order a few.. Glad they have that drivers side manifold three bolt gasket! That thing was a major PIA to make!
Old Sep 24, 2015 | 07:43 PM
BlackGMC's Avatar
Resident Retard
Yep. I tried just using rtv there but i kept blowing it out. That remflex gasket held nicely. Just remember they are not reusable and dont over TQ them. Each gasket comes with TQ amounts.
