Header studs
Old Sep 22, 2015 | 11:56 AM
GRRR65GTO's Avatar
Default Header studs
Recently I've been battling exhaust manifold leaks on the log side, my stock gasket leaked with all the bolts still tight, put in a napa felpro gasket (not mls) that leaks still, so I bought a set of seal 4 good aluminum multi layer aluminum gaskets. I was wondering if its worth it to get header studs too. But are stainless ones going to be strong enough to support a turbo log? Because I know stainless is equivalent to not even a grade 5 right?
Old Sep 23, 2015 | 08:18 AM
tim wellington's Avatar
Default header studs
i am using header studs no leaks, factory gaskest and hi temp silicone .7400 miles mies on new build
Old Sep 23, 2015 | 08:54 AM
slowec's Avatar
My studs or stock bolts never leaked with reused stock gaskets. Are you prepping the surfaces by cleaning them real good. Common mistake...
Old Sep 23, 2015 | 11:37 AM
GMCtrk's Avatar
The flange is probably warped.
Old Sep 23, 2015 | 07:25 PM
GRRR65GTO's Avatar
Yeah I figured the flange is warped but what can you do to fix it get it machined? Wont it just warp again?
I thought about using silicone but then I have to worry about scraping the surfaces clean after, thats why I liked the factory gaskets
Old Sep 23, 2015 | 07:37 PM
George C....'s Avatar
Formerly ScreamingL
Use gm factory studs on all builds i do...can be had cheap and very stout
Old Sep 23, 2015 | 07:46 PM
GRRR65GTO's Avatar
GM makes factory studs?
Old Sep 23, 2015 | 07:56 PM
Formerly ScreamingL
Yes....you use them from a fwd v6...part numbers used to be listed on this site
Old Sep 23, 2015 | 08:09 PM
Vortec350ss's Avatar
interesting... didnt know there were factory studs. I'd love to see a part number
Old Sep 23, 2015 | 08:11 PM
Formerly ScreamingL
Yup full set cheaper then ARP been using them for last 8 years or so
Only down fall you gotta order extra since a v6 doesnt have enough
Part numbers used to be a sticky
Think its like 40 bucks or so
