Head choice for 4.8 forced induction
Old Oct 3, 2017 | 08:35 AM
99silveradoman's Avatar
Default Head choice for 4.8 forced induction
Sbe 4.8 going to be running a s475 at around 12+- pounds it has the stock 862 heads now and I plan on pulling them this weekend for ls9 gaskets should I run the 862 or find some 243s
Old Oct 3, 2017 | 08:47 AM
Sevex's Avatar
Snail Fab
What are your power goals? The heads that are on it will probably get you where you wanna be on 12lbs. I would save that money and put it elsewhere.
Old Oct 3, 2017 | 09:43 AM
Since you are pulling them, take them for a decent valve job and get good valve springs. That is it.
Old Oct 3, 2017 | 10:16 AM
I'd be more than happy with 700 as a weekend toy for me and my son and I'm sure the 60e won't last long so that's where I plan to spend money saved
Old Oct 3, 2017 | 10:17 AM
What do you suggest valve wise I have the btr .660 dual springs
Old Oct 3, 2017 | 10:37 AM
BudRacing's Avatar
If you're still on the 60e, the trans upgrade should be priority #1 in terms of budget. If you're making anywhere north of 600hp you're on borrowed time.
If you can find a set of 243/799 heads for a deal you can't pass up, then by all means grab them while you can. But I wouldn't seek to pony up just yet. Swapping heads is definitely something that can wait.
Old Oct 3, 2017 | 11:01 AM
kbracing96's Avatar
Unless you're cutting the heads for bigger valves don't waste your money on a machine shop valve job. GM's machining is better than most older machine shops.
Old Oct 3, 2017 | 01:41 PM
I picked up a 80e a couple weeks back for a pretty good deal so that's what I had in mind after the 60e I heard the 862 heads flow good and compression is decent
Old Oct 3, 2017 | 02:51 PM
That is an interesting point. Good info.
Old Oct 4, 2017 | 12:05 PM
Merctech2's Avatar
Good advice if you have a new truck low miles. If heads are off do the valve job.
