head and cam
Old Mar 30, 2009 | 10:19 PM
2000sierra6.0's Avatar
Default head and cam
need a little help im looking for a head and cam package by the way i have 2000 sierra scsb with a 6.0 lq9 vortech supercharger running 8psi long tubes e fans 4l80 3.90 gears and wheatley tuned iwas looking at the tsp package i dont know to go with a stage 2.5 ls6 head or the 2.5 l92 and on the cam im lost i have the stock converter but i whant to go with a 2600 any help will be appriciated
Old Mar 30, 2009 | 10:57 PM
00Silv4.8's Avatar
I wouldn't really recommend more compression with FI, do a smaller pulley and a can and you should be good. I'd you really want heads but keeping compression hop minimal do some ported 241s. They'll breathe a little better with small compression gain
Old Mar 31, 2009 | 12:00 AM
Rick_Vor's Avatar
Good advice. The LQ9 is already 10:1 so unless you're going E85, you are pretty close to max on compression. Unless you are going for an all out system (ie:forged bottem end), high $$$ heads are a pretty low bang for the buck. There are too many examples of 700+ RWHP LS1's on LS1Tech with stock 317's. Spend your cash on a blower cam, a smaller pulley and Meth (if you don't already have a kit). You can reach your stock short block HP max on stick heads without breaking the bank.
Rick
Old Mar 31, 2009 | 12:19 AM
Rick_Vor's Avatar
Like I said on the heads...
https://ls1tech.com/forums/forced-in...ted-worth.html
Rick
Old Mar 31, 2009 | 12:42 AM
grate thanks i will keep my heads, i have the smallest pulley vortech make for my supercharger and i only make 8psi, any good blower cam will a 90mm tb fit my stock intake, where can i get a good meth kit
Old Mar 31, 2009 | 02:20 AM
00Silv4.8's Avatar
look around.
Sponsors------------------>
WTB adds, ebay, CL, etc.
and making 8psi on the smallest pulley? buy a better blower IMO
Old Mar 31, 2009 | 02:41 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Use the search function, and do your research before anything.
First of all for the Cam I would recommend the GT2-3 or GT-7 many have used them with boost, and got great results. The 90MM T/B won't fit because you have a 78MM So unless you get a 90MM intake that won't work. The meth Kit you Can Google and find different brands and names dependeing on what your wanting to spend.
GrooveCityZ71
Aug 31, 2015 12:05 PM
JFortner5
Aug 12, 2015 08:46 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Aboss
Jul 9, 2015 10:28 AM
