hd tensioner ...
Old Aug 5, 2010 | 12:08 PM
idahoblkss's Avatar
Default hd tensioner ...
any of you guys got any pics of the magnuson hd tensioner installed because the one i got buy looking at it , it doesn't make sense on how its going to mount in my truck. the hd tensioner i got is round with a single hole going through the middle and the stock tensioner has like 3-4 bolts holding it on the water pump. post some pics if you can if not let me know how to mount this thing , thanks
Old Aug 8, 2010 | 08:33 AM
04SilverCrew's Avatar
see if this helps...
https://www.performancetrucks.net/fo...tensioner+pics
Old Aug 8, 2010 | 01:54 PM
idahoblkss's Avatar
Originally Posted by 04SilverCrew
thanks that was better then nothing .. this is what was wrong i ordered the tensioner from magnason and they didnt include a bracket to mount it too i guess i was just suppose to mount it to thin air... the guy on the phone could of told me i need a bracket to mount thins thing the only reason i know that i need a bracket is because of dave sent me a pic of his mounted . thanks dave!!
Old Aug 8, 2010 | 06:21 PM
TIM Z's Avatar
11 sec. Truck Mod
Glad I got mine from leftcoast joe, He knew excactley what was needed to make it work, if your still having probs give him a call.
Old Aug 8, 2010 | 07:07 PM
idahoblkss's Avatar
yours came with the brackets and stuff ?
Old Aug 8, 2010 | 08:02 PM
2004SSS's Avatar
they probably thought you have a magnacharger kit already and the bracket could possibly be the same for both tensioners .
Old Aug 10, 2010 | 01:52 PM
idahoblkss's Avatar
stock bracket is way different then th hd tensioner bracket, i called joe at leftcoast and he is taking care of it good guy. ill post pics of the parts when i get them to show people that are looking to do this too so you know what all is needed.
Old Aug 10, 2010 | 02:35 PM
BlownChevy's Avatar
blownerator
25 Year Member
Cant expect a tensioner that was designed for a Magnuson to work on a Procharger.
Old Aug 10, 2010 | 02:47 PM
Mangled03gmc's Avatar
Baltimore Whore
I would think for that kinda money the tension should come with a mounting bracket.. I will give them a call, see if they will make it right
Old Aug 10, 2010 | 05:53 PM
BlownChevy's Avatar
blownerator
25 Year Member
Like I said, a tensioner that we designed to work with our system will NOT work with a Pro Charger. If you would like your money back on the tensioner please call and speak with David.
