Good Turbo set-up for 5.7L???
Old Dec 6, 2005 | 09:37 PM
Default Good Turbo set-up for 5.7L???
Could you guys tell me what parts i need to change for what im wanting to do-
550 to 600hp-
Good spool time- about 15psi on 5.7L -
Reliable also... (Daily boost will only be like 4 to 6psi...)
Set up-
Garret T70 T4 turbo- (T3 .70 A/R) Or should i go w/ a T4???
Turbosmart Type-2 Vee BOV
Turbosmart Pro-gate 48 wastegate
Intercooler OPEN TO SUGGESTIONS
TurboXS dual stage MBC
Turbosmart Pneumatic fuel cut defender-
Vortech FMU
Warlbro 255lph fuel pump + MSD inline electric fuel pump
Please add to or edit the parts as you see fit- Remember- 5.7L 550 to 600hp... 15psi
Trying to keep stock cam- I will be redoing the valve train though- valve springs/ valves/ retainers/ seals/ 1.6 rollers/ port&polish...) if that makes a difference...)
Old Dec 6, 2005 | 10:08 PM
8ALTNG's Avatar
I would recommend using the search button when looking for all these setups. It mught help you to get a awnser quicker than waiting for other members to awnser back Just a thought.
Old Dec 6, 2005 | 10:49 PM
vanillagorilla's Avatar
What kind of 5.7L is this? I noticed you mentioned 1.6 RR's.
Old Dec 7, 2005 | 12:24 PM
silver-mod-o's Avatar
Hunt&Fisherator
I would say the Banks skit would be the way to go.... they have done some beautifull work on small block chevys.
Old Dec 7, 2005 | 03:44 PM
LT1- The banks kit is TT my friend which i dont see the need for- plus i can do it my self for much less $$
Old Dec 10, 2005 | 09:19 AM
Hunt&Fisherator
well you say you are looking for a quick spool-up which you definitely get with a twin set up and the HP you want is absolutely going to bet met and most likely exceeded with the kit. I would look at them just for $h*ts and giggles. Its free to read up on them.
Old Dec 10, 2005 | 10:40 PM
ColtSteele's Avatar
If you're building a kit yourself - have you looked at turbonetics?
T-66 - Racegate Wastegate - Godzilla BPV/BOV - Spearco Intercooler (ofcourse there's less expensive that's just as good, just stickin with the theme ) That's a pretty good combo too.
Old Dec 14, 2005 | 09:58 PM
what about twin Garret TB0308 turbos- Off of 3.8L buick turbo regals? i can find two of em for like $1000
can they hit the 600 mark together and can they keep up the boost on the top of the rev range or will they fall on there face?
sauldgold
Jul 23, 2015 02:15 PM
Jake75
Jul 22, 2015 09:20 PM
4B11T
Jul 13, 2015 03:48 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
