go 90mm TB or go home?
#41
Originally Posted by zippy
You ask a good question of why use the IAT or ECT to add timing. My question would be why not. Why wouldn't you have a 1º to 2º more timing when the engine is at around 170º compared to say 195º. The same goes for the intake air temperature. When you're driving around in good cool air and the blower isn't hot you have considerably less chance of any knock occuring compared to when you're driving in hot weather or you've heated the blower up from a few wide open runs. I've gained quite a bit changing those tables in 60' time as well as gains in milage by running a bit more timing when the engine and blower air temperature aren't running hot. The tables you see aren't just something I pulled out of the sky, those are numbers that have been adjusted many times from actuall drive time with hours of logging in Radix trucks.
I can see both sides here, and I understand what you are saying....I feel it gets more confusing when you do it this way.
I just dont see the advantage of adding timing in a correction table. My understanding is a correction table should be used to protect the vehicle in extreme conditions. There has to be a reason why GMs calibrators do not use the correction table to add timing under normal driving conditions. I see that on a stock SS calibration that GM adds +2* @ 23* of IAT.......talk about extreme. I also see that in the same calibration +3* @ 77* of ECT, for driveability...this is what keeps the vehicle from stumbling until it reaches normal operatiing temp. Why use this for HP tuning? When it comes to tuning for HP, I feel it should be kept simple....this is not rocket science after all, its just tuning for power. If we were talking about driveability calibrations then yes, that would be science.
I guess it all depends on how you put your pants on in the morning, I start off with the left foot.
#42
Notorious BIG
I didn't add the 5º myself, I assume Holty did that. With the extra 5º that would put him at 24º of timing not including any added by the IAT or ECT table if he's running it cool. That is too much timing. I don't even see a reason to have added any timing over what it was set up for already and if any was added it should have been no more than about 2º total. Most people gaining alot by adding timing because they are running the 90mm are claiming that it's because of the lower IAT's. If you're programming a Radix properly to begin with your IAT table should be adding the timing at lower temperatures already.
obviously you don't want me doing things like this on my own, so from now i won't touch tunes that i get from you.
i'll load the original tune that you sent me back in and get some new logs. the only reason i added the timing was just to see what would happen since the new 90mm TB went on. i got a little anxious.
#44
Don't take that as me taking a shot at you. I'm simply saying that adding the timing number that many others have done may put yours into a danger zone or into the low octane table. As you probably noticed, adding the 5º to yours likely didn't make it any faster.
#45
An example of working with the heat tables is Holty's truck. He ran a: 12.667@105.60 1.801 60' with an AWD Silverado SS. Those numbers are with a stock camshaft, stock stall speed, and 20" wheels. Working the tables is the only way you're going to be able get a Radix truck to have enough timing to get that hard of a launch and still be pulling out the big end without KR* pulling all of it's timing.
#46
#47
Originally Posted by dewmanshu
This is what sold me! Start out high with cool temps, end low with high temps. Win win. Why lose timing at the end or have to give it up in the beginning?
I have NEVER messed with any of the correction tables that we are discussing, and I always start and close out my 1/4 run with the commanded timing.
#48
Originally Posted by BlownChevy
Again, I still hold firm, properly tuned....the gain from the TB will be 35-45 hp.
On a cammed radix'd 5.3L maybe. On a properly tuned (prior to 90TB) radix'd 6.0L, You will not see that increase.
Every application is different. I think that is key here.I am running 19* overall timing with meth and am hitting a bit of KR in the 5K range.
#49
Notorious BIG
that is correct, i could not really feel any difference after adding the timing.
#50
What spark are you commanding?
How many #'s of boost?
Then at the finish, crossing 1320 what is your IAT?
spark? (I imagine for you it's the same as when you started, cuz you have it like that
jk)boost?
With whatever you answer with I am gonna suggest extra timing at the green light to produce a better 60'...but my suggestion isn't gonna be any good for when you cross the 1320, it'll be too high. Hence Zippy's add some timing down low while it's cool and you get away with it. I don't think the arguement is you can't get the same degree from the beginning to the end, I think the debate is, you can get more timing in the beginning for more power but taper it off back to a safer degree once the IAT starts to heat back up.
