go 90mm TB or go home?
Moderately Differentiated
Originally Posted by BlownChevy
no it will not, unless you are running on the ragged edge now.
Notorious BIG
Originally Posted by krambo
The 90 TB is worth it albeit I have NOT seen any reduction in intake air temps hence no bump in timing. My injectors are spent with my application. The only thing I have that you do not is a cam. How is your fuel pressure up top?
Originally Posted by Holty
Fuel pressure is good (for the most part) at about 62psi. For some reason i see a "blurp" on my fuel pressure gauge at the top of second gear where my pressure drops to about 44psi for about 2-3 seconds, than jumps back up to normal pressure. I've done scans when this has happened and don't see any issues with my a/f ratio or kr, so don't know what thats about. i'm hoping the magnavolt will fix it.
Hey!!! You can't be online! You're supposed to be working!!!!LOL
