Gen 4 5.3 turbo/cam combo?
Old Aug 21, 2019 | 05:39 PM
94heritage's Avatar
Originally Posted by smokeshow
It was most definitely the cam. However, my requirements may be different than others. You could say it's not the cam and blame the 1.32 turbine housing if you wanted to wait 10 seconds for it to spool. But that is unacceptable for me. Race is over by then
If it takes that long to spool then theres a hotside/wastegate issue, boost leak, or the tune is not where it needs to be because that turbo and a good cam/converter combo should be at full tilt by 4000 or less on a 385 with 10:1 plus compression.
Old Aug 22, 2019 | 09:02 AM
smokeshow's Avatar
Mod with training wheels
not surprised it spooled slower, but you said it didn’t pick up any power with 3 more psi.
you talking at lower rpm or peak? My 80/92 1.1 T6 makes full boost at 3200 on the foot brake. Once converter is locked it builds boost below 2k
That was a hypothetical used to explain something. Mine didn't have issues spooling. It ran decent, but not well enough for the combination.
I've broken down the science as to why that combo suffered from the cam a number of times, but people's eyes tend to glaze over before I finish. If there was a sensor that could tell you how much inert gas stays in the combustion chamber and the intake port when cam profile gets more aggressive, people would start getting the picture...
nickamberg
May 16, 2015 08:26 PM
454navyss
Nov 22, 2011 05:47 AM
slowlsx
Mar 24, 2010 07:37 AM
TurboGibbs
Feb 7, 2007 03:00 PM
