Gear sizing with 80e and turbo
Your turbo should spool pretty good! I’d go 4:10 or 4:11 gears, It does sound like you’re in the same boat as me! My converter is right where I like it! I daily my truck, so I didn’t want a high stall converter. If I were you, I’d do the gear change first to see if you really need to loosen up your torque converter.
i think I’m going to go buy two cheap used tires, 285/40r17, and have the put on my 17’s to see how the truck reacts to the 4:11 gears! A 26” tire on my setup is right at the same ratio of having 4:11 gears in my rearend.... I’m sure I can go to some hole in the wall used tire place and find a set for $50-$60
So I need some advice on what gears to run in my truck. Factory my truck had a 60e which I swapped for a 80e, stock gears in the rear are 342 right now and it really feels sluggish from a dead stop. I’ve got a new set of 4:11 gears and a tru-trac, but I’m not sure on going that low of a gear. My tires are 31” OD, oh and I’m running the newer pt88 billet wheel turbo with a .96a/r t4 turbine housing. It lights up pretty quick once going, easily 10psi by 3200rpm from a dead stop...... just really wanting some opinions on what gears some other members are running in their turbo trucks, mostly ones running lower gears and how they act on the street and highway. Thanks!
I can build more boost on the line with just the foot brake than I can hold traction for leaving. I also have 32.8" 22" tires. It will just blow them off if I don't leave easy.
What a/r size is the turbine housing on the s480 you’re running, t4 or T6, and what size turbine wheel? How does the PI 3200 converter your running act on the street, under normal “city/traffic” driving?
Reason I ask is because I’m thinking about having my multi disc re-stalled higher. I love how it drives like stock, but I can only foot brake it to around 2200-2400rpm. Just curious how you like the PI converter and how it acts.
I've got a precision 7675cea with 12# of boost. As mentioned you can just brake boost or 2step it from a dig. I wanted 4:10 gears just to help out with how heavy a crew cab is running 31" tires.
