Garage clean out. DIY pipe kits, and more cheap.
Old Oct 31, 2017 | 11:10 AM
TrickTurbo's Avatar
Truck Sponsor
Default Garage clean out. DIY pipe kits, and more cheap.
We are cleaning out the shop and lots of turbo parts need to go.
Perfect time if you want to get into a turbo kit or just needing some misc. parts for your build. We will not finish these parts. Parts sold as is, most are Porto type, trial for, seeing if it's something we wanted to bring to market.
All parts are good and usable.
I will also be adding to this list as i get more moved around in the shop.
DIY aluminized hot pipe set with T4 cast manifold.
Manifold is new never bolted up. 2.5" Crossover material and 3" down pipe is aluminized. You will need a small section of tubing if you want to route like most crossovers are.
Comes with flanges, crossover gaskets, studs and nuts.
I have 2 sets of these.
1000.00 Shipped.
Aluminzed 3" down pipe. I have 2 of these. For T4 turbo.
150.00 Shipped.
White powder coated 3.5" thick wall cold pipe. With 2 bungs welded in.
50.00 shipped.
3" stainless steel 2pc downpipe set up with 46mm gate vented back into down pipe.
Set up for t4 turbo.
225.00 plus shipping.
Driver side unfinshed turbo manifold. Set up for t4 or t3 turbo.
Needs end area and gate tube area welded up.
Has 2 gate location flanges welded on. One under the turbo flange is not opened.
We were playing with gates locations
300.00 Shipped.
