full boost
Question, when do you reach full boost? My boost starts in at about 3000 and reaches 12lbs at about 4500, is that good? I think using dual 2 1/2 has made it spool slower. I was just curious how much lag your supposed to have. I am looking at a 2800 stall, what is a good one? I am running a GT67 with .96 exhaust housing.
Originally Posted by Lord Aries
On my 5.3L i can hit full boost (8lbs) at around 3,200rpm... Not sure what is going to happen with the new 404 when it goes in...
Its going to spool much much faster -- you want to upgrade
I was talking with an old mud racer and he said to run NOS on the intake of the turbo, and point the nosel directly at the impellers. NOS is discharge at 900psi and spools it right up. We also talked about using an air fitting on the exhaust to spool it faster, down side to that is you have to carry an oxygen tank. Has anybody heard about this or tried either?
Originally Posted by quicksilverado
It will spool faster, but it would run out of breath up top.
If i need to upgrade i will, don't mind the idea of a bigger turbo...
still no takers on this subject????
