fuel system upgrade
Old 10-23-2011, 11:24 PM
black04's Avatar
GM switched the order of the wires in the plug around a few times over the years.
Old 10-23-2011, 11:29 PM
chevyboy.520's Avatar
So has anyone with a 04 or new, actually have a racetronix hot wire kit work? Or is it only going to work on 03 and older?
Old 10-23-2011, 11:32 PM
black04's Avatar
I've never ran it but it should work if you switch some wires around in the plug so that they match. Shouldn't be too hard to figure out. There are 2 wires for the fuel level sender and then a positive and negative for the pump.
Old 10-23-2011, 11:38 PM
Looks like I'll be doing that soon. I'll post up what I find, so if ppl with 04 and newer order it, they know what to switch to make it work. Unless it's just my kit that I bought that's back wards
Old 10-23-2011, 11:41 PM
black04's Avatar
Eh I know in between 04-06 they switched it around twice so depends what you have. Ill see if I can dig up the 2 wiring schematics. I had them saved somewhere.
Old 10-23-2011, 11:43 PM
Originally Posted by blue0453
Ok guys I am currently running a single walbro returnless style setup. I am looking to upping the boost to around 14/15 psi. What do you guys recommend for fuel changes? I am looking for the most cost affective setup. Not looking to spend alot of money, just something to get the job done. thanks Nick
I've been wanting to do the same thing. I have 1 walbro with factory wires. And I bought the hot wire kit, but it hasn't worked yet. Hopefully I can figure it out and get it working. Then it looks like I might get one of those aeromotive pumps to drop in. See where that gets me.
Old 10-23-2011, 11:59 PM
graysilverado5.3's Avatar
My truck is an 03 but motor/harness/fuel system etc, are out of an 05. I used the fbody hotwire kit.
Old 10-24-2011, 12:03 AM
black04's Avatar
Could only find this in my documents. This is the pinout for my 04 but i know GM also had a plug with orange, black, grey and purple wire.
Old 10-24-2011, 12:20 AM
So just switch A and D? In that pic and it should work?
Old 10-24-2011, 12:21 AM
My buddy had a 01 TA and he rolled his car. He gave me his hot wire kit, to try out. But the connectors are completely different.
Quick Reply: fuel system upgrade
