Fuel rail pressure
Old Aug 23, 2011 | 05:36 PM
kbracing96's Avatar
Originally Posted by idahoblkss
adjusting your regulator isn't going to affect your fuel pump . only way to adjust your fuel pump pressure is though voltage right?? your pumps are like a on and off switch and unless you give it less or more voltage it should act the same no matter what the regulator is set at , please correct me if im wrong ??
Fuel pumps will flow more max lbs/hr at lower pressure.
Old Aug 23, 2011 | 06:24 PM
black04's Avatar
Hmm I'm curious what 60s would support then with a base pressure of 43psi
Old Aug 23, 2011 | 09:07 PM
MikeGyver's Avatar
Originally Posted by kbracing96
... If your injectors are big enough, run 43lbs/hr boost referenced and adjust the tune accordingly and you will have a happy fuel system.
What would you adjust in HP Tuners, other than "Injector Flow Rate vs. KPA VAC" ?
Old Aug 23, 2011 | 09:35 PM
kbracing96's Avatar
That should be all you have to adjust. With boost ref pressure reg, it would be a flat 60 for 60lbs/hr injectors rated at 43psi.
Old Aug 23, 2011 | 10:18 PM
MikeGyver's Avatar
Thanks. I am going to see if it helps a little. I have been running a stock pump for quite awhile now, accumulating funds to sort it out. I should probably just put a wood block under my gas pedal instead!
Old Aug 24, 2011 | 12:08 AM
$nake Charmer's Avatar
Thanks for the help guys I think I found some information like your talking about kb... It calculates ve and fuel pressures an it told me like 43.5 @ 9 psi..?.?.?. I'm not sure if that's idle or after boost like you were saying... I have 2 fuel pumps in my tank a factory and a wal 255. I'm only using the stock one right now. I also have the vac line hooked up to the fpr.
Old Aug 24, 2011 | 11:43 AM
charcold-bowtie's Avatar
What?^ 43.5 at 9psi? makes no sense
Old Aug 24, 2011 | 11:06 PM
43.5 psi fuel rail pressure ( idle) and running just 9 psi of boost
Old Aug 25, 2011 | 07:38 AM
MikeGyver's Avatar
Fuel pressure is adjusted with the key on, engine not running, when the pump runs for a couple of seconds. 43.5 psi at idle might be 47 or something actual fuel pressure.
Old Aug 25, 2011 | 12:04 PM
And that sounds like what your injectors are probably rated at, 43.5lbs. Also, i doubt you have 9lbs of boost at idle
