Fuel rail pressure
adjusting your regulator isn't going to affect your fuel pump . only way to adjust your fuel pump pressure is though voltage right?? your pumps are like a on and off switch and unless you give it less or more voltage it should act the same no matter what the regulator is set at , please correct me if im wrong ??
Thanks. I am going to see if it helps a little. I have been running a stock pump for quite awhile now, accumulating funds to sort it out. I should probably just put a wood block under my gas pedal instead!
Thanks for the help guys I think I found some information like your talking about kb... It calculates ve and fuel pressures an it told me like 43.5 @ 9 psi..?.?.?. I'm not sure if that's idle or after boost like you were saying... I have 2 fuel pumps in my tank a factory and a wal 255. I'm only using the stock one right now. I also have the vac line hooked up to the fpr.
