Fuel pumps
Old Jun 15, 2011 | 09:06 AM
nonnieselman's Avatar
Default Fuel pumps
Has anyone tried to run a Bosch 044 pump inline with a Walbro 255 feeding it out of the tank?
Tryin to figure out a way to do a simple fuel system on my buddys truck for E85. Goin with a 76mm turbo and see how much boost it will run before it runs out of injector or pump on a 5.3
Old Jun 15, 2011 | 09:23 AM
MikeGyver's Avatar
I did. It was maxed out on a stock LQ4 with 9 psi boost.
... to figure out a way to do a simple fuel system on my buddys truck for E85. Goin with a 76mm turbo and see how much boost it will run before it runs out of injector or pump on a 5.3
Simple would be nice, but you're going to need complicated to run moonshine and boost.
Old Jun 15, 2011 | 11:13 AM
Moonshine is some good stuff
Thinking about seeing if he will try to run the Bosch 044 in tank and run it off a HOBBs switch and let the Walbro do most the work till he gets up in boost pretty good. Think that would be a better idea?
Old Jun 15, 2011 | 05:33 PM
MikeGyver's Avatar
Turn on the second pump at 1 psi and he will be well into boost before it takes effect.
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
