fuel pump?
Old Jan 27, 2009 | 09:35 PM
xxwackerxx's Avatar
Default fuel pump?
so i noticed my fuel pressure was about 5psi lower then what its suppose to be. haynes said key on truck off 55-62psi...im gettin 49-50ish. queastion is, if i get an inline pump would that help or is it limited to what the intake pump can push?
Old Jan 27, 2009 | 09:51 PM
xxwackerxx's Avatar
ment to say intank...
Old Jan 28, 2009 | 05:08 PM
Mort's Avatar
What year is your truck?
Old Jan 28, 2009 | 05:41 PM
xxwackerxx's Avatar
2002 5.3 sts(5psi) w/ meth
Old Jan 28, 2009 | 07:03 PM
Mort's Avatar
Sounds like your in-tank pump may be getting tired or your FPR is not operating properly. You should see 52 psi or so at idle, 58 psi general driving and cruising and up to 63 psi or so WOT. I see 54 psi KOEO(ff).
Check your FPR, after a drive, by pulling off the vacuum line to the intake manifold. If it is wet with fuel then the FPR needs to be replaced. If it is not the FPR then your pump may be getting weak and need to be replaced.
If your in-tank pump is in good shape an in-line 255 LPH fuel pump will work well and should not be limited by your in-tank pump.
I have been running a Walbro GSL392 255 LPH pump since April 2005 and it is still going strong. At 10 psi boost I see 68 psi fuel pressure up to my shift at 5600RPM.
So yes an in-line pump is a great addition to your fuel system if the other parts are in good condition. In fact with a turbo it is a must imho.
You should also have 44 lb/hr injectors if you don't have them already and NGK Tr6 plugs.
Good luck, Boost Safe!
Old Jan 28, 2009 | 08:16 PM
xxwackerxx's Avatar
thanks alot. yeah i pulled off the vacum to see how high my pressure would be without it. it bumped a little. i think ill add a inline for now. i got 44lb marine injectors. just got the TR6's, had some cold autolights in there untill checkers got in some TR6's. if the in tank goes though, the inline isnt going to be able to pull the fuel needed right?
Old Jan 29, 2009 | 12:54 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yeah, if the in-tank pump goes, the inline will not pull enough fuel.
Old Jan 29, 2009 | 07:11 AM
xxwackerxx's Avatar
thanks guys
Old Jan 29, 2009 | 06:36 PM
xxwackerxx's Avatar
just ordered the intank walbro from summit...hopefully that will solve my trucks drinking problem...ha
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
