Fuel pressure issue....
Old Dec 29, 2010 | 11:58 AM
5.3 GMC's Avatar
Default Fuel pressure issue....
I was driving around the other day and happened to look up at my fuel pressure gauge and noticed my fp had dropped from 52-54 cruising to 50. Well it had me wondering so I got on it and fp jumped to 58 at wot but then all a sudden fell off to low 50s so I stayed out of it and went home parked it. Any ideas why this happened? Bad regulator maybe? It is the stocker. I have a walbro 255 in tank and 38lbhr injectors. It's been fine until know.
Old Dec 29, 2010 | 01:26 PM
Gadgetized's Avatar
Seems weird that the pressure went up when you stepped on it. Do you have a Magnavolt, boost-a-pump, or something like that? What is your battery voltage doing?
Old Dec 29, 2010 | 02:09 PM
5.3 GMC's Avatar
Walbro 255 in tank is all. No boost a pump of any kind. Didn't really pay attention to the voltage at the time
Old Dec 29, 2010 | 03:05 PM
04SilverCrew's Avatar
I just replaced my fuel pressure gauge and transducer for a improper reading issue... so don't rule out the gauge. May want to tap in a known good gauge to compare. Then look at the regulator. Good luck.
Old Dec 29, 2010 | 03:32 PM
5.3 GMC's Avatar
Thanks for the heads up. Ill try that
Old Dec 29, 2010 | 09:07 PM
hog's Avatar
hog
Pressure should jump when you step on it. Its the vacuum referenced fuel pressure regulator. Low manifold vacuum=high fuel pressure, high manifold vacuum=low fuel pressure. Its why idle pressures are always lower than WOT or when you rapidly open the throttle.
peace
Hog
Old Dec 29, 2010 | 10:25 PM
Gadgetized's Avatar
Oops, Hog is right. If you have referenced boost it will increase.
Old Dec 30, 2010 | 01:11 PM
5.3 GMC's Avatar
So why would it just now start falling off? Before it would stay...any ideas on what to do?
Old Dec 31, 2010 | 05:59 PM
mike058's Avatar
Highway hauler
Have you checked your fuel filter? when you remove it and dry it out, you shoud be able to blow through it. If you have to strain to blow throgh it, get a new one.
Old Jan 1, 2011 | 12:37 PM
5.3 GMC's Avatar
Haven't checked it but it's only been on there about 2,000 miles.
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
