Fuel injectors for 1000rwhp turbo build
Old Feb 25, 2014 | 08:21 PM
Biggsw784's Avatar
What injectors are you turbo guys using to make this kind of power with the factory ecu??? This turbo stuff is all new to me. I have always been a nitrous guru. The engine is a brand new ls2 block, Manley crank and rods and j&e pistons with a cam Crower spec'd out to this build which is 232/224 @ .050 566/566. The heads are stage 3 wcch l92s and bought a Holley hi ram ls3 intake fitted with a fast 102mm big mouth throttle body. Trick Turbo is building a badass kit for this thing too. The trans is a 4l80e with a rossler transbrake and a 3600 circle d multi disc converter. This is all going into a 01 Sierra regular cab short bed. I'll start a new thread once I start putting the truck together. Thanks for any info on the fuel side of things.
Old Feb 25, 2014 | 09:14 PM
idahoblkss's Avatar
what kind of fuel are you going to run ? pump ,race, e85 ?
Old Feb 25, 2014 | 09:41 PM
Biggsw784's Avatar
Sorry I guess I should add that. 93 pump gas with a meth kit also. Thanks
Old Feb 25, 2014 | 10:14 PM
Whistle Truck Guy
I'm doing a similar build, had Rick build my kit as well. I went with 160lb injectors, but I'm going to be running E85. With pump gas you could get away with running a smaller injector, maybe something like a 95lb or 120lb. You sure want to err on the side of too much injector tho. Nowadays there are plenty of high flow high impedance injectors that can cycle fast enough to produce a good idle... But they aren't cheap. Low impedance injectors work really well but you have to buy a driver for them.
Old Feb 25, 2014 | 10:31 PM
Atomic's Avatar
I have a gauge for that
127lb injectors with twin walbro 400s. I have the same setup, good to ~1300rwhp.
Old Feb 26, 2014 | 07:27 AM
Biggsw784's Avatar
The truck is going to be 4 linked rear suspension with a 9" ford rear end so there will be a fuel cell. The pump I am going to run is a A1000 with -10 line.
Old Feb 26, 2014 | 11:49 AM
sprayedenali's Avatar
I have some FIC2000's id sell if youre interested. a little over kill for you now but then you could run e85 if you ever wanted
Old Mar 2, 2014 | 07:45 AM
TURBHOE's Avatar
I just bought the FIC Bosch 95's single tip. Should be here this week!! Nice thing is they came with HPT numbers. .
Old Mar 2, 2014 | 12:49 PM
blownescalade62's Avatar
Looking at some ID 1000's for my rebuild now
Old Mar 2, 2014 | 11:56 PM
Biggsw784's Avatar
What's the best way to fit a bosch injector to my factory harness?? The bosch has a ev1 connector. What connector is on my factory harness?? 01 sierra with a 5.3.
