Front mount pics :)
Old Feb 14, 2008 | 05:29 PM
TrickTurbo's Avatar
Truck Sponsor
Default Front mount pics :)
We finsihed our Intro Kits intercooler kit. IC kit comes with all the tubing, brackets, couplers needed to fit the 06 and earlier trucks. Bolts in extremely easy, I think. You will have to drill and tap a couple of holes in the frame, or use self tappers. We send 5/16 x 24 stainless bolts with the kit. The brackets are asjustable, depending on bodylifts, etc. Core is 3" with 2.5 inlet and outlets. The 2.5 tubing routes so easy around and through the chassis. All tubing will have a bead rolled end, or welded end to keep the couplers from sliding off.
Depending on bumper configuration, some cutting maybe need to increase the air flow getting to the intercooler.
Stock fan shroud would also need a little TLC just so it does not rub the silicone boot. Clears the fan with plenty of room to spare.
This set up was fitted on our 2000 1/2ton RCSB.
3.5 going over pulley area, once all pipes are installed and tweek you should have about 1.0-2.0 inches of clearance. Pic just looks tight. You can also see the shroud needs a little TLC.
Straight on shot.
Old Feb 14, 2008 | 05:54 PM
TURBHOE's Avatar
hmmmm that is all
Old Feb 14, 2008 | 06:32 PM
Turbocoop's Avatar
sweet, I need to sell my car so I can get a kit from you
Old Feb 14, 2008 | 07:21 PM
BigCountryx's Avatar
Damn I need to sell my K5. Anyone need a mud/trail rig. lol...............but I'm serious!
Would this kit be big enough to support a turbo upgrade?
Old Feb 14, 2008 | 08:47 PM
WJ MARK's Avatar
Im sure it would be fine.
Old Feb 14, 2008 | 09:54 PM
cool, I was thinking 2.5" would be a little small. Seems like most people run a 3" setup.
Old Feb 14, 2008 | 10:13 PM
TrickTurbo's Avatar
Truck Sponsor
Turbo outlet I.D. is smaller then 2.5. 2.5 will keep the velocity up and fit real nice. 3.0 is an option but adds cost in lots of areas. We can and will build to fit our customers requests.
This kit is rated for our Intro kit.
chacho44
Aug 17, 2015 03:36 AM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
Deceptarado
Jul 8, 2015 05:24 PM
