Front Inlet vs. Rear Inlet & Front Drive vs. Jack Shaft drive
Old 07-12-2019, 03:48 AM
8 Second Truck Club
Blown06's Avatar
Default Front Inlet vs. Rear Inlet & Front Drive vs. Jack Shaft drive
Someone give me a bit of an education. What are the pro's and con's of a front inlet and/or rear inlet? What are the pros/cons of a front drive vs. jack shaft drive?
Old 07-12-2019, 05:44 AM
12secSS's Avatar
On a jack shaft you can over drive the shaft pulley to make more boost.
Old 07-12-2019, 03:18 PM
BigKID's Avatar
All the debates I have read are mostly about air flow to the blower/compressor inlet. Rear inlet is supposedly the worst due to the bends in the inlet track/j-tube. Front inlet/front drive is better due to less bends but has the shaft imposing a restriction. Front inlet/Jack Shaft has least restrictive inlet. The jack shaft can be over driven as stated previously, which is an advantage, but some feel there are additional drive losses thru the shaft.
Old 07-13-2019, 02:34 AM
8 Second Truck Club
Blown06's Avatar
So it would be safe to say that front inlet/jackshaft drive is the best of all combinations...
Old 07-14-2019, 10:45 AM
I have a gauge for that
Atomic's Avatar
As long as the jackshaft doesnt explode.
Old 07-14-2019, 12:10 PM
terravast4's Avatar
Yep. I have heard horror stories of jackshafts breaking
Old 07-16-2019, 11:04 AM
YukonJack's Avatar
Not sure about front inlet, but with the rear inlet, a couple of the supercharger screws under the intake plenum going to the back are a major B to get to.
Old 07-16-2019, 05:55 PM
milkey57's Avatar
Do a CF jackshaft, the Gto guys seem to have good results with them on the tvs2300
Old 07-16-2019, 07:34 PM
YukonJack's Avatar
I almost went with a 2.9L Whipple for a Camaro, a front feed, but went with the 2.3L complete kit for my truck. Cheaper and complete with no custom stuff needed. 2nd guessing myself now. Could have went bigger and pulleyed down if needed.
Old 07-16-2019, 08:58 PM
makes children cry
_zebra's Avatar
my vote's for the front inlet due to less restriction & the better pulley options.
i'd also recommend doing a manifold spacer to help your intercooler & IATs out, and if yours is for cathedral-port heads (has triangle ports instead of rectangles), i'd recommend porting those out to match the heads.
i wouldn't necessarily say 'more' boost, but you can make the same boost using bigger pulleys so as to reduce the belt width required to prevent slipping.
i thought it was the carbon fiber ones that had problems... my metal one's been just fine for 8yrs.
Quick Reply: Front Inlet vs. Rear Inlet & Front Drive vs. Jack Shaft drive
