Forced Induction and Towing
Old Feb 23, 2006 | 03:22 PM
  #21
Whippled 496's Avatar
Well like i tell the woman who cleans my house and cooks my dinner (the wife )....."would you rather i was sitting at the bar or working on my truck?"
Hey coon, i was checking out your video's in your sig (Very cool). The one where you do your 0-60 run......it would be cool if you could video edit a kid kicking a ball into the street and chasing it, right about the time your hitting 75.
Old Feb 23, 2006 | 03:58 PM
  #22
CoonToot's Avatar
Funny you mention that...that recording is the 2nd one, as the 1st run I almost hit a doe! Glad I was looking up and not at the gauges, or else i would have some splainin' to do.
Old Feb 23, 2006 | 11:31 PM
  #23
203Cree's Avatar
alrighty, i got in touch with Jeff over at Whipple and told me that the setup I have is the way they come with the deleted electronics. It senses vacuum at the intake to allow the spring to open/close depending on the state of pressure measured. He tells me it is not advised to try and adjust the linkage (even though it may look inviting). He recommends that i purchase the pully 2 sizes smaller to achieve boost sooner than I am. He said running 93/94 octane (which i do) and living at virtually sea level, i should not have any problems jumping to 7lbs of boost even without the intercooler. He said under most conditions you will only actually be into 7lbs of boost 5% of the time anyhow. So it looks like I had the install correct.....and Coon was right, that if i want boost sooner to grab the smaller pulley.
The guy at Whipple is correct. Don't touch the linkage. Adjust your actuator. Pop those bolts loose and adjust where it sits on that mount. Lightning guys have been doing it for awhile now. Trust me, it'll change where your boost comes on at. A smaller pulley is a fix, but not the ONLY fix.
Here's a link that might help you better understand what I'm saying.
Worst that can happen is you have to put it back the way it was.
Rob
Old Feb 24, 2006 | 10:27 AM
  #24
Thanks 203, good tip!
calsdad
Jun 14, 2023 11:07 PM
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
Chevy305
Sep 28, 2015 09:21 PM
Lthompson
Sep 21, 2015 04:34 PM
