Flexible Intake Hose with Whipple?
Old May 27, 2014 | 08:00 PM
Will's Avatar
Pat, I appreciate all your help.
I am not trying to question you at all, but I am just curious. Even at full vac, is that more than stock?
I guess what I am trying to understand, is if they make these products for intakes, why would a supercharger setup be any different under vac than stock? From what I understand it just forces air. I didn't think vac was any higher than stock.
Old May 27, 2014 | 09:24 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You're thinking about it wrong. If you were placing those tubes before the throttle body, you would be just fine. After the throttle body is a whole different story.
Old May 27, 2014 | 10:26 PM
GRRR65GTO's Avatar
Good catch 03 i was thinking of this like a procharger, youre right about the elbows they arent that rigid and would collapse somewhat in vacuum id think. Youll just have to use all aluminum bends then, i could have if i really wanted to but the silicone ones were the easy way
Old May 28, 2014 | 04:16 AM
03sierraslt's Avatar
The elbows won't collapse somewhat, they will suck closed and stall the motor. I've done all this before. Myself, jamesbond2509 and mikegyver did this at the same time and learned the hardway.
Old May 28, 2014 | 10:51 AM
Will's Avatar
Just wanted to update you guys to get your opinion. After reading on some other turbo forums about how I can mock up the piping I need, I think I have decided to mock up the angles I need using this.
Since it won't stay very well, I am going to fill it with some of that great stuff to make it stay in place. From here, I will have my fabricator bend or cut and bend the aluminum pieces that I have into the angles I need. This should only be for the bends around the radiator. What do you guys think?
Old May 28, 2014 | 10:52 AM
Last Call's Avatar
TOTM: January 2007
Perhaps you could get some 4" aluminum tubing and two 90 degree couplers?
I did that on my Whipple 2.9 and it seems to be working fine.
Old May 28, 2014 | 11:23 AM
Will's Avatar
Do you have the 34" radiator? That is really what is making this difficult. I would be good if I had my old smaller radiator, but I wanted the extra cooling.
I have also already purchased a 3" universal kit, so I have several pieces including 90's, 45's, 180's, etc. None of them fit without modification.
Old May 28, 2014 | 11:50 AM
Last Call's Avatar
TOTM: January 2007
I have the 34" radiator, but don't have an A2A set up like you. I don't have any pictures now, but I can take some tonight or tomorrow.
Old May 28, 2014 | 01:03 PM
Completely different, his TB is up stream of the blower piping so apples to oranges.
Old May 28, 2014 | 01:35 PM
Will's Avatar
Pat, what did you think about my flex hose to use as a template to bend some pipe? Do you think it would work?
