finaly got blowed
#22
Well, I'll bite. I have an LQ4 w/ 3.0" pulley that makes around 7 psi. A 2.6" pulley will, of course, technically work if it fits on the blower (at work w/ slow connection so didn't look at it). Two things to consider, though:
1: On my setup I am hitting 86% duty cycle on the Magnachrger-supplied injectors (42 lb marine). A 2.6" pulley will require more fuel and you may need to go to bigger injectors.
2: You will be spinning the blower very fast, which generates a lot of heat, which the intercooler may not be able to remove.
If I were you and were dead set on the 2.6" pulley, I would consider installing a meth/water spray system. This will cool your IAT's down, and the meth could make up the fuel deficiency.
#25
im getting some 60lbs inj and dual walbros installed so ill be done with the fuel right , il be adding meth soon but i was wounder can i use a 50shot in the mean while so my iats can go down
#28
Performance Trucks Sponsor
Nice truck!
Like he said above, those intake temps are gonna be pretty hot! A meth kit is a good idea.
I'm curious to see if the new setup is faster than the old setup.
I put my money on the NOS, I don't think the Radix will push it to 11.5 or quicker, that's just me though, what do you think?
#29
well i dont think so either but will c i know my old setup had more cuz of traction issue i hit 11.5 with a 1.66 60ft and went a lil sidways at half track http://www.youtube.com/watch?v=fC79q...eature=related but im hoping with this setup i can get an 11.5 then ill spray again gotta love the n20
TrickTurbo
Sep 23, 2015 08:41 PM
Velocity1
Sep 22, 2015 01:32 PM
Orlerr
Sep 21, 2015 08:32 PM
